Question about Cameras
The camera wont load
My camera is set up and everything and it's working but the camera part is having troubling shooting up
  • kakima Dec 19, 2016
    Hi Katrina Perry, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
2 Suggested Answers
  • 4961 Answers
SOURCE: trouble shooting
Clean the xbox 360 with a laser lens cleaning kit like this one:
Posted on Aug 19, 2012
Factory reset
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset.
If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
Dec 08, 2013 | Samsung ES30 Digital Camera
I have an old Nikon Lite Touch Zoom 100 AF camera and I am having trouble loading the film. Can you use Kodak Advantix APS film in this camera or should I be using manual loading film instead?
This camera uses 35mm film, not APS film. 35mm is a larger format, giving MUCH better results, at the expense of having to manually pull the leader across to the take-up spool each time you load a roll.
Dec 29, 2010 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
Wont turn on
I assumed that you loaded a fresh battery set and with correct polarity ,otherwise it does give such signal.
If you have the user manual,please check the other alternatives on trouble shooting section.
If you do not have a user manual you can visit the site below where instruction manual copies for Pentax,
It's not an official site, but the manuals for downloading are better quality copies and in color
where possible: and they have the MZ30 too.
Mar 16, 2010 | Pentax MZ-30 Film Camera
The flash wont work on the camera...still
1. Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies. * When shooting in the Twilight or Handheld Twilight mode. * If shooting with the Burst or Multi Burst mode. * Shooting with Sweep Panorama. * Shooting with the Fireworks or High Sensitivity mode. * If an external flash is connected.
2. You can also Initialize the Camera. Touch the Home option. Then, select the Main Settings and then, select the Main Setting2 option. Then, select the Initialize option to OK.
3. You can also try to select the Flash Forced option to ON. The Flash Forced option is located under the Flash Settings.
Jan 10, 2010 | Sony DSC-T70 Digital Camera
Canon xti work turn on properly
Unfortunately, per the problem description, it seems your camera has an internal malfunction in either the main board or the DC/Dc converter printer cicuit boards.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the option of pay for its repair.
Best regards,
Apr 28, 2009 | Canon Digital Rebel XTi Digital Camera
Having trouble with my camer shooting slow between pictures
You might have a USB virus or spyware infection in the memory card. I suggest you have Kodak develop the pictures then wipe the memory card clean. And the pictures might be dark because of the camera settings and or the development quality. Try resetting the camera. Hope this works.
Jan 27, 2009 | Canon EOS-5D Digital Camera
Cannot get Error to go away
If it's a D lens or similar, check that the lens is set to its minumum aperture (and locked) - ERR normally means that the lens is not at its minimum aperture.
If your lens is a G lens, then the camera is probably faulty.
May 05, 2008 | Nikon N75 with 28-105 lens 35mm Film...
Shooting black frames only
assuming you have the exposure set correctly (if u set way underexpose, the frame will appear black). Try put it in "Auto" mode and see if it works.
If it doesn't, your mirror mechanism may be faulty. One way to check is to take a photo of 2 seconds or longer. Look into the viewfinder, can you see anything through the viewfinder during these 2 seconds?
Jan 24, 2008 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
