Question about Garden
My1206 international 1206 tractor the pto does not dsengage
  • 237 Answers
Check the fluid level, if ok be sure the selector spool that linkage is attached to is not broke and has full up and down movement with no obstruction on the down side. If spool is moving properly the clutch pack may be burned up.
Posted on Dec 19, 2016
I need an exploded view of the PTO on my 1957 B250 I/H tractor
Not sure if this will help but it will at least put you in contact with people knowing that stuff - even has a manual search
International Farmall Tractors Discussion Forum
Dec 29, 2014 | Garden
Where is transmission filter located on international 756
I t is behind teardrop shaped cover below r ight hand brake drum.
May 20, 2014 | Farmall IH Tractor 706, 756, 806, 856,...
PTO cable: Ariens 960160021
Sounds like you are missing a return spring. Your PTO if it's mechanical engage has a tension spring to bring it back when disengaged.
Apr 09, 2014 | Ariens Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
How do i remove the PTO from an IH 856. The lower PTO shaft broke and the unit will not slide out
make sure all the bolts are out should be 1 short bolt and 8 long bolts to remove pto after that it is stuck to gasket. short bolt is in lower left corner of housing
Dec 26, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
I have an old 4020 and the PTO will not stop when the PTO handle is in the off position. Can you tell me what is likely wrong and is it a major fix?
The internal brake has gone bad... and yes it is a major fix, because the tractor will have to be split to get to it...
You probably can stop it with a gloved hand by grabbing a hold of it...then you can quickly get a PTO shaft against it and get it hooked up...any drag from a machine should be enough to keep it stopped...
If it is pulling harder then that then you have even bigger problems, as the throwout is bad inside and the PTO is constantly engaged...
Jul 30, 2011 | John Deere 4020 Gas & Diesel Tractor...
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Oct 11, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
