Question about GPS
I have a redcore concept S2 that is one year old. When you try to turn the temp light flashes but unit will not come on. Cleaned it several toms. The first time helped but not now. Any ideas?
  • 878 Answers
SOURCE: Dishwasher
Tom, three things you want to check. 1. the heating element. Remove the leads from the element and ohm it out. Should read between 11 and 31 ohms. 2. Check the high limit thermostat. This sits right behind the drain pump on the right and inserts into the tub housing. Remove the leads and check for continuity. 3. The vent wax motor is inoperable. Check for continuity on the wax motor terminals. You can also put the dishwasher into a service mode to check the operation. In this sequence press high temp scub-energy saver dry-high temp scrub-energy saving dry. This will put it into a auto test mode. Let it do it's thing. If you need any further details, you can email me at back.
Posted on Mar 19, 2007
  • 3422 Answers
SOURCE: Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Posted on Feb 25, 2008
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
  • 149 Answers
SOURCE: Beverage Air
1. check for dirty condenser sometimes if its dirty enough, it'll trip the compressor.
2. if condenser is dirty, well pull out the old garden hose and hose down the condenser (turn off unit first!)(i don't want any accidents... je je je)
if you did step 2 and nothing yet, suspect faulty relay/ overload/ start capacitor failure (relay and start capacitors fail more often then the overload.
hope to he of some help today.
  • 78 Answers
SOURCE: i tryed to update today
This is caused by the device being disconnected before all files were updated- the fix for the issue is here
Posted on Jan 27, 2009
How do you change remote batteries in Redcore Concept R1 and what type battery?
The battery compartment on the remote should be identified and you can open it to identify type.
Jan 20, 2017 | RedCore R4 IR Heater Color: Wood"
My flame quit working in my red core heater. - Redcore S2 IR Stove Heater - Space Heaters, Inc.
Rating: 3.7 - ‎29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
FAQs About PowerHeat - DURAFLAME ' TWINSTAR ...
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
Customer Reviews: RedCore Concept S-2 Infrared Stove ...
Jan 10, 2016 | Heating & Cooling
Red Light flashing
it may be because of the problems as u described air filters and fan .but try first with the filter,u can find it at amazone or flipkart
May 03, 2017 | Epson Computers & Internet
Vacumm Condenser light flashing
Your unit is sensing that the condenser fan is running at a lower rpm than it should. that is how you get the signal. You will need to replace the condensor motor if your coils are cleaned already. That is the only cure for your problem. I hope this helps you out.
Jul 16, 2009 | Sub-Zero 690 Side by Side Refrigerator
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
I know today it was 99* but my moms a/c isn't cooling?I took the filter out and man o man the fins or coils are covered with dust?can i clean them or do i need a Pro?I'm not sure i can get my hand all the...
call a reputable co. get it tuned up most have maintenance programs, should be checked will be time and money ahead the out side unit needs to be cleaned to. and what you spend on cleaning the unit you would have spent trying to cool a house with a dirty unit that has very low performance. good luck Tom.
Jun 23, 2009 | Ruud UBHC Air Conditioner
GPS Logo
27 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
