Question about Coffee Makers & Espresso Machines
I have been buying the same 12 cup maker every year and it stops perking in one year or less and I can't understand why this makes me so mad do not understand!
SOURCE: Braun Aromaster 10 coffee maker
I just purchased a second-hand 12-cup Braun Sensor coffee maker and thought I had the same problem: coffee water sat in filter and wouldn't run through. Used strong vinegar and water run-through several times and still the water sat in the filter. Then I turned the carafe to the right, so that handle wasn't sitting full middle..... coffee flowed right through. Try it.
PS: does anyone know where to find the operating manual for this model? 'Sensor' on the front; model 3092 on bottom; made in Germany.
Posted on Dec 19, 2008
SOURCE: farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Posted on Feb 09, 2009
CHA55Y
  • 13 Answers
SOURCE: My Starbucks Grand Barrista 12 cup coffee maker stopped working.
from what i can see they have pumpo issues..... try your warranty although i guess that'd be long gone after your many "years" of ownership.... anyway, get an expresso machine, they produce much better coffee by far :) Goodluck, CHA55Y....
Posted on Jun 14, 2009
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
  • 236 Answers
SOURCE: Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Posted on Nov 21, 2009
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Sep 29, 2012 | Faberware 12-55 Cup Coffee Urn
How to measure coffee for 45 cups. Also is a filter needed.
The Instruction Manual for your coffee maker can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
100-CUP MODEL #33600
Water Level Measure of Ground Coffee
100 cups 6 ¼ cups
80 cups 5 cups
60 cups 4 cups
40 cups 2½ cups
Do not make less than 40 or more than 100 cups of coffee at one time. Use electric perk or regular grind coffee; a filter liner is not necessary.
Mar 09, 2011 | West Bend 33600 Coffee Maker
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
My stainless steel Mr. Coffee maker just quit perking coffee and the water does not run totally through. It has been perking slower and less quantity but today I cleaned it by running vinegar through it...
this is set up on a conventional mr coffee; if the hot plate is not as hot, it will not work, on the newer ones, a small chip could be getting hot, and like a car, it will either shut down or work part time. send it back to mr coffee, and they'll repair it, but it might be cheaper to replace it.
Jul 02, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Farberware 4 and 12 cup percolators stopped making good coffee
Nov 05, 2008 | Coffee Makers & Espresso Machines
Coffeepots not operating by not getting hot enough
Hi. Sue, Problem is you're buying China pot's. One of 2 things can cause that problem. The Thermostat or the keepwarm element. 9 out of 10 it is the thermo. The parts are not available in the USA. I have a eBay auction site. I have to make the thermo's out of USA ones. They are 8.00 plus 2.00 S/H. My eBay name is ron622c. If you want to stay with Farberware you can buy a used one or if you are lucky a new one. But don't buy a China one, Good luck. Ron
Jul 06, 2008 | Faberware FCP280 Coffee Maker
Need measurement guide
We use 'em every sunday at church - 1/2 cup grounds for every 10 cups water. Allowances: finer coffees will use less grounds, and the more you are making, the fewer grounds you need ( or vice versa- the less you are making, you may need to increase grounds a bit, as perk time will be shorter
Nov 07, 2007 | Faberware 12-55 Cup Coffee Urn
Mr Coffee
If your coffee maker is under a year old, take it to a authorized service center for free repair or replacement.If its over a year then the complete heating element assembly must be replaced.However, this part is only available to authorized service centers and is not sold to consumers.
Nov 04, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
