Question about Garden
Need a manual for Noma Performance Snow Blower model 629108X31A
Or a diagram for the replacement pins for the auger. What are they like? Or can anyone give me the Part Number for the auger shear pins & nuts
trippssmengi
  • 76 Answers
SOURCE: auger on my snow blower won't turn.
First take a look at the shear pins they will be located on the augers going thru the auger and auger shaft, if they look ok then you need to take the belt off, with the belt off try to turn the im peller by hand. If the impeller does not turn then you need to look to see if something is stuck in the impeller or in the auger. If nothing is stuck in between anything then I would have to say it's going to be the gear box. If the impeller turns then look to see if the auger is turning also while turning the impeller. If the auger doesn't turn then it's probably the gear box. If it does turn then you have an issue at the pulleys
Posted on Jan 07, 2009
  • 144 Answers
SOURCE: My MTD 10hp auger will
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Posted on Jan 09, 2011
ToolBoxHero
  • 171 Answers
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Posted on Jan 10, 2011
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
ToolBoxHero
  • 171 Answers
SOURCE: I have a new Troy
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
ladywritr2
  • 954 Answers
SOURCE: older john deere 5/20 snow blower won't throw snow very far (3-4ft)
Some of the informative videos on YouTube may help you, such as this one by DonyBoy: https://www.youtube.com/watch?v=bbAq7m0d2qM
Posted on Apr 23, 2015
I have a Toro two stage snow thrower that has an auger issue..left just spins as it want the right moves snow....how do I fix...the machine is 13 years old can't find any answers....help please.
The shaft has shier pins that break when an object gets caught in the auger. This prevents further damage. You will need to replace that pin. Make sure you stop the blower, unplug the spark plug before working on it. The pin holds the auger to the shaft. Turn the auger until you see the hole through the shaft and insert a new shier pin.
Dec 12, 2016 | Garden
Change auger belt on noma snow blower
GO TO GOOLGE AND ASK THE QUESTION THIS WILL BRING YOU TO YOU TUBE AND THIS WIL SHOW YOU HOW TO REPLACE THE BELT
Feb 22, 2015 | Garden
Looking for the Repair Manual for a Noma Performance Snowblower 622515.
Hi A,
Here you go,to the link. Questions Answers for noma snow blower manuals
Oct 18, 2014 | Garden
How to remove the right hand auger from a nova performance snow blower model 629104x31
remove the whole auger from machine and then remove the shear bolts. Slide the auger off shaft
Aug 25, 2014 | Garden
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Snow blower auger stops in snow
There are cotter pins on the second stage blower shaft. I would inspect these. Also, check sheer pins in front auger assembly.
Dec 03, 2013 | Garden
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
I have a honda ccr2450 and with the heavy snow today it clogged and now the auger doesnt seem to turn to speed and is slipping, not throwing snow etc, is this an easy fix. thanks carl
You have a two stage snow blower. The first stage in your auger and they are equipped with a safety shear pin. Consult your owners manual for proper pin or shear bolt replacement.
Feb 26, 2011 | Toro Garden
I have a 3 yr old 26" snow blower. I ran the machine up against hard packed snow/ice and now the auger spins freely and all shear pins are still in place. The secondary impellor functions fine. I...
I am going to assume the belt is good if the impeller it running. You can check the belt by removing the plastic cover in the center of the snow blower.
With the unit safely turned off reach in and turn the blower by hand while putting a little resistance with your other hand on the impeller. Does the shaft from the impeller to the gear box turn?
Does the shaft that the augers are attached to turn? If the impeller shaft turns but the auger shaft doesn't, the gearbox in the front is bad and will have to be replaced.
I the auger shaft turns, check your shear pins again. Sometimes they will break but still stay stuck in the holes. Actually take one out and check it.
If it is a Craftsman you can get a manual from managemyhome.com and parts from searspartsdirect.com. You will need the model number of the snowblower. The number looks like 247.123456.
Any other questions please ask. Do't forget to rate this answer!
Jan 16, 2011 | Craftsman Garden
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
