Question about Honeywell Heating & Cooling
Thin blue wire coming from spark on Honeywell iid is not connected. Where does this wire connect to?
  • Cheryl Witteman Dec 18, 2016
    This is on a Raypak RP2100 Lo Nox swimming pool heater
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 86 Answers
SOURCE: RTH6400 Honeywell - where does the blue wire go.
it all depends how things are wired inside your furnace downstairs on a basic system blue is usually a common - C and yellow is for cool - Y just leave the jumper in from R & RC R is 24v power and RC is 24v power in Cool yuo will just have to squeeze the new wire in with it before you get to far i would open up the doors on you furnace and see where the connections are in there so you dont blow any fuses
Posted on Jun 28, 2009
  • 43501 Answers
SOURCE: Wiring problem?
Yes to everything!!
You have it figured out!!
Just make SURE that the blue unused wire cannot touch any of the other wires, it will wreck your transformer in a split second.!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Posted on Nov 25, 2009
  • 588 Answers
SOURCE: I am trying to install a Honeywell RTH2510
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Jan 09, 2010
  • 588 Answers
SOURCE: Need wiring diagram for Honeywell RCT8100
The old thermostat has a second stage heat which is W2. The new one doesn't have second stage heat.
The wiring your describing on the old thermostat is telling me you have a heat pump with second stage heat and the new thermostat is for air conditioning only. You will need to get a thermostat for a heat pump.
Posted on Apr 02, 2010
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
Need help wiring a thermostat with 5 wires don't know what rh and rc mean.and how they connect. thanks
Hi, on a thermostat like you have, the RC and Rh have a jumper wire that connect the two using the red -hot wire coming in. This means R-cooling and R-Heating. So, take the red and connect to either one, and make sure you use a jumper wire to connect rc and rh together along with the red wire coming in. Yellow will go to Y for cooling, W for heating, and G,green for the fan. If you have a blue wire left over, it is a spare, unless you have no yellow. If it doesn't have a yellow, use the blue wire for cooling. Some contractors will use blue instead of yellow. If not, the blue is a spare wire.
A/C, Heating Contractor
Apr 10, 2011 | Honeywell Heating & Cooling
I am wiring a honeywell thermostat model number ct87n if I select fan on the fan runs when out on auto /heat nothing but if I put on auto / cool and adjust the dial to a low setting the hea comes on....
there is it all depends on how many strands of wire are in there, they start at 2 wire and go to i think 8 wire and maybe more.
The wires are as follows:
1. red = power to stat.
2. green = fan control
3. blue or yellow = ac
4. white = heat
w1 = 1st. stage heat
w2 = 2nd. stage heat.
i am on line if you have any questions. wally
Feb 22, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
Heat will not shut off
Take white off of Aux, and attach it to L
Feb 16, 2009 | Honeywell Programmable Thermostat Heater
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
Dec 28, 2008 | Honeywell Electronic Programmable...
Replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
