Question about Whirlpool Refrigerators
Where is the temperature control on a whirlpool refrigerator
2 Suggested Answers
kjmac
  • 97 Answers
SOURCE: Temperature control
hiya
the thermostat should be inside the fridge compartment usually near the light.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
How to change temperature control on Whirlpool refriigerator?
There are many different models of Whirlpool Refrigerators and not all have the same temperature controls. Are you replacing the thermostat or a electronic digital controls? Look inside the door frame of the fresh food compartment on walls and door frame itself for the model number. JT3_5_2013_5_42_46_am.jpg
Mar 05, 2013 | Whirlpool Refrigerators
Where is the reset button on a ED25SM Whirlpool refrigerator
refrigerators do not have a dedicated reset button, but you can, however, reset your refrigerator in the event of a technical problem.
resetting the main unit
  • 1 Turn the refrigerator's temperature control switch to "Off."
  • 2 Unplug the power cord.
  • 3 Plug the power cord back into the wall.
  • 4 Turn the control knob to adjust it to the temperature you want. leave cord unplugged for about 30 seconds. hope this helps ! good-day !
Dec 03, 2011 | Whirlpool Refrigerators
It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
For more information it may be helpful to look at http://www.whirlpool.com/ or contact your local whirlpool support number
May 17, 2011 | Whirlpool Refrigerators
Whirpool control just went off, no light but refrigerator is working goo]d. should i replacer the tempreture control
If the refrigerator woks satisfactorily according to the temperature you have already set before, there is no need to replace anything. I assume it as an internal loose connection and if you are in need of that temperature controller, you can get it fixed.
Apr 21, 2010 | Whirlpool GD2SHGX Refrigerator
Temperature control
hiya
hope this helps
Aug 03, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrig/freezer problems
Could be due to a bad temperature control in the refrigerator section allowing the temperature to vary to much between the on and off cycles. This would also cause things to partially melt in the freezer and refreeze.
Jul 10, 2008 | Whirlpool ET8GTKXKQ Top Freezer...
WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Dec 31, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
