I've just connected my Samsun LCD monitor to a new HP desktop. I had been with a Dell. Part of the horizontal as well as vertical data is off the screen. I can't figure out how to adjust it with the buttons on the bottom of the monitor.
you are probably not going to adjust it with the buttons. You need to go to the video settings in Windows and choose a resolution that fits the screen. I would be willing to bet that the new screen is not the same aspect ratio as your old one. You can change resolutions until you find the correct one for your computer and screen.
What is the difference between a NEC 1880 SX and a NEC 1810 SX Monitor? ALSO What is the difference...
(More)
What is the difference between a NEC 1880 SX and a NEC 1810 SX Monitor? ALSO What is the difference between a NEC SX and a NEC FX monitor?
Hi have the same problem - started about a year after I got it. I took the covers off to look at it...
(More)
Hi have the same problem - started about a year after I got it. I took the covers off to look at it and there's nothing to adjust. It's simply a very poor design. The weakened spring mentioned in another posting is definitely part of the problem on my unit but because the center hinge is also frozen I cannot get all the covers off to get a good look at it. That makes it a real pain in the *** to get the mechanism apart to get a closer look at it so I just left it. Way to go Samsung.
No there was nothing unusual. I had been in the habit of raising and lowering the screen. The hinges...
(More)
No there was nothing unusual. I had been in the habit of raising and lowering the screen. The hinges became loose and the last time i tried to raise the screen I realized that the center hinge was frozen in place. Can these hinges be opened? Is there a way to restore them?
The monitor is no longer supported by the flexible hinge. Is there any way I can tighten it? I have...
(More)
The monitor is no longer supported by the flexible hinge. Is there any way I can tighten it? I have had the monitor for just over a year.
