My Defy Laundromaid 1300m has filled with water and then the electricity went off. How can I restart it to start agitating without adding more water?
  • 27 Answers
SOURCE: Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Posted on Nov 02, 2007
  • 4 Answers
SOURCE: No water is coming in the washer before the agitator starts
The above answer is copied from Washerhelp Please only use small quotes and link to the original source
Posted on Apr 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore H3 doesn't agitate or drain reads F02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&!!
Posted on Sep 29, 2010
SOURCE: I have Defy Laundromaid
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Posted on May 08, 2011
ZJLimited
  • 17970 Answers
SOURCE: I have a Defy Laundromaid
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
Posted on May 28, 2011
Defy Laundromaid Electrologic 1300 wiring diagram
Contact Defy directly and request the wiring diagram.
Feb 26, 2018 | Washing Machines
I have a Defy Laundromaid 1300m that doesn't let water in or start with the washing cycle need help please
Sounds like your inlet valve isn't opening. With it not opening the cycle won't start by default.
May 11, 2017 | Washing Machines
My defy laundromaid 1300m does not stop water flow, even not in use water keep flowing into the machine
there are shutoff valves behind it . use them till you get the other valves replaced
Dec 20, 2016 | Washing Machines
My defy laundromaid 720 does not stop the waterflow once the drum is full, which leads to water running out the bottom of the machine and then gives me an error LE
problem either in the water level control switch or the solenoid valve that shuts off the water
if the water doesn't shut off but it progresses progress to wash while still filling, it will be the water solenoid valve
Oct 08, 2016 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
I have Defy Laundromaid 1300. I was getting an E9 message.
Sep 21, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
