Question about Saeco Coffee Makers & Espresso Machines
Error code 5 on saeco minuto coffee machine - Saeco Coffee Makers & Espresso Machines
    New Friend:
  • 78 Answers
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Posted on Dec 30, 2016
What does error code 23 mean on the Saeco Minuto Coffee machine
I believe error 23 is a sensor error for the lever on the front of a minuto.. It cannot be repair at home and would have to go to a service center.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Jun 10, 2015 | Saeco Coffee Makers & Espresso Machines
Saeco xelsis error code 5
Error 5 on your machine usually means it needs a new pump. The pump may be too weak to do the job.
Always try to descale the machine before doing anything else. If you can't then you will have to take it in for service.
Please visit our service center page.
If you need descaler visit this page.
Dec 30, 2013 | Saeco Coffee Makers & Espresso Machines
Saeco error codes
I don't think this is the case. The E04 code is about lubrication of the brew group. This is directly from Saeco support in Germany. However, the problem does persist. It seems to be an issue of poor design more than anything else.
Dec 22, 2013 | Saeco Coffee Makers & Espresso Machines
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Open Questions:
Defect Saeco Odea Giro. Red exclamation flashing fast. Mashine is function only in service mode. A defect in Saeco Odea Giro. TYP 0310R ser. number. 9007SA40523803 Please help for repairing the machine. I bought the automatic coffee machine second hand. After unpacking, I discovered that someone was intruding into it cracked plastics and handles. By common check, I discovered the 1st fault - a broken piston catalog number 11003468. This is quite a common fault with these machines. 2nd defect leakage of the valve. Even one O ring was missing. I replaced all O-rings with new ones. Then I went over to check the individual sensors: Level sensor in the tank - OK Sensor closed coffee bean hopper - OK Sensor of closed door on the brewing unit side. - OK Sensor on the waste container - okay When I wanted to try switching on a microswitch that detects the presence of the brewing unit in the hole, I did not find contact. So I removed the wall behind the brewing unit and found that there were two microswitches near the toothed wheel. I checked their functionality. Both well. I assumed that one of them was not at his destination. The one with the green connector I supposed to indicate that the brewing unit is in place. I moved him to the top. I checked the state of the electric motor and lubricated the gear. I returned the wall back. Next, I ran the diagnostic mode and checked other components: a Boiler - Heats up b The pump - presses correctly and the green diode flashes during its operation and shows the activity of the flowmeter c solenoid valve - switches correctly d the grinder grinds and during its operation the green diode flashes and reveals the activity of the speed sensor in the mill e the brewing unit is moved to the top position and to the basic position without any problems Other things I've done: The whole coffee maker is cleaned, deep decontamination is performed using the diagnostic mode. Check the flow meter clean without oxidation. Check the tightness of all hoses. Both boiler thermostats are checked. Removed and thoroughly cleaned the mill. Despite this, the machine behaves as follows: Turn on the machine and fne the mill shaft. The red exclamation mark flashes very quickly. The green light of the boiler heating is not lit or flashing. However, the boiler is heating up properly. When I eject the tank water flow, the red exclamator lights up permanently. After the tank returns, the red exclamation mark will flash rapidly again and the green indicator the boiler is heated will light up properly. When switched on, the Indycatter does not light the cup. Only a drop of water drops and coffee beans lit up. Can not prepare coffee, can not refuel hot water. All this can only be done in diagnostic mode. In the diagnostic mode, I also de-aerated the machine. Both the nozzle and the coffee outlet through the brewing unit. Self-cleaning will not start. I do not know anymore, maybe there is a bug in the electronic panel. Will anyone advise me? Thank you.
Mar 09, 2018 | Saeco Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
1,131 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
