Question about Sewing Machines
WHAT IS THE EASIEST WAY TO UNDERSTAND A CROCHED PATTERN DIFFRENT STICHES
  • Sewing Machines Master
  • 11,732 Answers
Search the internet for:
crochet (and then input the stitch code, ie HDC)
There will be multiple web sites and videos that explain how to make that particular stitch. You can also search for beginner crochet instructions.
Posted on Dec 18, 2016
How should the first stich in each row be knitted. I.e opposite of what the pattern calls for or pulled off Thank you.
The first stitch of the row is usually the chain that you ended in the last row. The chain essentially builds the height of the pattern to the next row so the stitches are even height from beginning to end. After you have made the chain, then begin with the first stitch in the next row pattern.
So, if the pattern says to knit 3 (or purl 3), that 3 stitches allows the height for the next row.
Jul 19, 2017 | Sewing Machines
How to use the stich pattern on singer model 5932?
Download the instruction manual free from the Singer Sewing Machine site; it's on page 17.
Jun 20, 2014 | Singer Sewing Machines
I am knitting a hat that is smaller than the instructions call for . How do I determine the amount of repeat stiches between the decreases for the crown
you could just use a smaller needle and use the pattern as is..to determine the repeats,look at the the pattern and see how many repeats they have in it.decrease one st per repeat all the around..
Feb 08, 2014 | Sewing Machines
I have forgotten how to work my Decorative stitches on my Bernina 930
select the 1-20? stich pattern on top of the unit, then select the pattern you want, select widest stich and turn the length adjuster to the length that best suits that stich, (it could be from almost zero to full length depending on the pattern)
Feb 07, 2013 | Sewing Machines
My sewing machine juki is not running. The stiches is too tiny and unless you pull the material it won't run . Do you havethe idea why and how can I solve it?I was using it before and all of a suddent it...
I would go to there web site and Down load the manual to the model you have. You should find what you need to know about setting patterns in it.
Feb 22, 2011 | Juki Sewing Machines
Thread comes out of needel and into gears
are you threading the needle from the front of the machine to the back ?? that will help as itwill not sew at all the other way , just a thought
Feb 18, 2009 | Sewing Machines
Yamata FY7568 only stiches ----------
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Feb 11, 2009 | Brother Sewing Machines
How to adjust the stich lenght on a juki ddl 553 strite stich.
I still don't understand this. I have acquiured a juki DDL 553 recently to discover I have no idea how to change the stitch length and that there is no reverse stitch. I have pressed the black button and have tried to turn the side?( the wheel?) but when i push down on the black button there is no way to turn the wheel it doesn't move, maybe there is some other part I'm supposed to be moving??
Jan 24, 2009 | Juki MO-655 Mechanical Sewing Machine
Machine will not sew forward without backstitching
You have selected the Stretch Stich (SS) mode on the stitch length regulator, just turn the knob around until you have a number 1 - 5 and that should be it.
The model number will be the last digits on the metal compliance plate with voltage etc.....looks like:
V / 1234 / 123454321 / 2016
www.bargainbox.com.au
This then would be a Model 2016
Nov 25, 2008 | Sewing Machines
Sewing machine problems
Having the exact same problem, oiled the machine, but I still can't change stitches...any advice?
Jun 29, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
