Question about Keurig Coffee Makers & Espresso Machines
Plugged b70 keurig into a 220 volt wont work now
  • 40 Answers
SOURCE: b70 keurig wont heat up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Posted on Oct 07, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
klipsan
  • 64 Answers
SOURCE: MY KEURIG B70 IS CONTINUALLY PROMPTING TO "PRIME"
Hi, Lauren..
You can download another manual here.
Cleaning any coffee brewer is essentially the same. The easiest way is to brew one or more pots of white vinegar... it'll stink up your kitchen, but it's effective at removing build-ups and mineral deposits. Be sure to follow up these "vinegar brews" with several "plain water brews" to remove all the vinegar!
Also, if your water reservoir isn't clean (open the lid & do a finger swipe), you can use a brush to clean it or - what I do - wad up a paper towel or two, attach it to the end of a long-handled wooden spoon, and use that to get down deep into the reservoir & scrub it as much as you can before the vinegar treatment.
Alternatively, you can spend $3 or $4 for packaged cleaning compounds at stores like Williams & Sonoma.
Posted on Mar 02, 2011
ventura538
SOURCE: The Keurig is not dispensing
the air pump in the machine might be locked up. if it is you will have to take the machine apart, not fun, and locate the air pump behind the water tank. take the pump apart and try to turn the pump manually until it moves freely. good luck
Posted on Jan 29, 2013
arnehof
SOURCE: Does Keurig manufacture a coffee
Yes,
They have started to sell them in England, with 220 v.
The Keurig K140.
http://keurig.co.uk
Posted on Aug 11, 2014
They plug it 110volts to 220volts
if the unit is built for 110 bolts and it is plugged into 220 volts, either the unit or the outlet circuit breaker is the problem. Circuit breaker can be reset - not so much for the coffee maker.
Check the circuit breaker and then see if another appliance will work. If not, the circuit needs troubleshooting. If the circuit works, then have the coffee maker serviced.
Mar 06, 2015 | Keurig Platinum B70 Coffee Maker
Power switch doesn't work.
The handle is not making full contact and it will not signal the next phase to start.
Jan 28, 2013 | Keurig B70 Coffee Maker
B70 wont prime.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
Does Keurig manufacture a coffee brewer that operates on 220 volts?
Yes,
The Keurig K140.
http://keurig.co.uk
Oct 14, 2010 | Keurig B70 Coffee Maker
Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Feb 12, 2009 | Keurig B50 Coffee Maker
I am moving to a 220 volt country
Get a transformer to take with you, but make sure it is sufficient
for the watts of the Keurig.
Aug 21, 2008 | Keurig B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
