Infinia 60PK950 60" 1080p Plasma TV no video display I have audio & relay clicks when TV turned on/off so I think power is ok. Used to be able to get video after turning off/on several times.
  • 1039 Answers
SOURCE: Powers off after several minutes
Check and replace swollen capacitors in power board.
Posted on Apr 25, 2009
ssebata paul
  • 159 Answers
SOURCE: phillips plasma wont turn on
check power supply
Posted on May 30, 2009
  • 188 Answers
SOURCE: no picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Posted on Jul 21, 2009
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
  • 6 Answers
SOURCE: Sanyo Vizon 42" Plasma DP42746 Was
This is a common problem with these TVs. You can download the official Sanyo repair manual for this TV (DP42746) at I uploaded it here when I had the same issue with my TV last year. The solution is almost always to replace the Power Board (Y-Main) and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop): 1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Posted on Aug 07, 2010
Fix my plasma tv
Check out the video below and familiarize yourself.
Although it may not be exact model.
Plasma TV Repair Tutorial Common Symptoms Solutions How to Fix Plasma TVs
Then start research on symptoms, required parts.
Apr 10, 2016 | LG Infinia 60PZ950 60-Inch 1080p 600 Hz...
Lg 50pj350 plasma tv wont power on, just a clicking relay. I didn't see an obviously bad capacitor and have never worked on something like this before so I replaced the power supply board. with the new...
Never think that only capacitors will make trouble to a TV circuit. There are many other components you can see inside it. Thousands of both tiny to large components are soldered together, to form a circuit. Even if a very small component fails to work, the fault related to failure to that components arises.
A relay click after switch On the the TV, and shuts down, can be of many couses, especially to Plasma displays. You should be sound in electronics, to troubleshoot fault Plasmas, because, the circuit of it will be so difficult to follow, even for an experienced technician.If you wish to know some reasons for the start-up shut-down to plasma displays, check the site linked here.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | Televison & Video
LG 5 Plasma no display or audio
Symptoms Possible problems
negative image
tv turns on and shots down in 2sec X or Y or Z
flashing pixels on screen
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
Dec 23, 2011 | LG 50PC1DRA 50 in. Plasma Television
I need an owners manual for anLG 55LX9500 if you click on the tap that says support on the right hand side there'll be an option to download the manual which you can then print.
May 12, 2011 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
I have been trying to add external RCA speakers ( 5 speakers with 1 amplifiler) to my LG PK950 directly through RCA audio put with red and white cable, but so far I couldn't get any sound coming out of my...
It are two things or the plasma not ordering this him the sign it gives audio or not this one connecting the amplifier to the audio exit the cables rca have to go connected in the audio exit of the plasma in the part of behind he says exit
Feb 12, 2011 | LG Infinia Series Plasma HDTV 50PK950
How can i add external speakers to my lg 50pk950 tv and still control with my tv remote without also adding an amplfier?
Use a wireless speakers system and connect it to the Audio Output RCA jacks on the back of your set( red/white). You can find various style to fit your decor. Google it.
Nov 30, 2010 | LG Infinia Series Plasma HDTV 50PK950
How to connect nintedo to plasma tv
Hi,things you will need,
  • Video game console
  • HDMI cable
  • Audio/visual cable.
  1. Plug in your video game console's power source.
  2. Connect one end of the game console's audio/visual cable into the corresponding slot on the console if you have an older game console. If you have a newer console, insert one end of an HDMI cable into your console's "HDMI OUT" port.
  3. Plug the red and white ends of the audio/visual cable into the corresponding red and white audio inputs located on the back of your Vizio plasma TV if you have an older game console. Plug the yellow cable into the yellow "Video In" input. Depending on which model of Vizio TV you have, the yellow input may be located either right next to the audio inputs or it could be located a few ports away.
  4. Plug an HDMI cable into one of your TV's "HDMI IN" ports, if you have a newer console.
  5. Turn on your video game console and your Vizio plasma TV. Press the "TV/VIDEO" button on your remote to cycle through the various inputs. You should eventually get to an input that's displaying your video game console's home screen.
I think that will do.
Have nice day.
Sep 25, 2010 | Nintendo Video Game Consoles & Games
How can I view my ipod pics on my TV screen
1. OK on your iPod and click "Videos" from the main menu. Click on "Video Settings" and then switch the "TV Out" function to "On" by clicking on it.
Plug the iPod audio video cable input to the correct iPod plug-in. The cable's input varies from cable to cable but will either plug into the headphone jack or the power output.
Plug the other end of the audio video cable into the television's video output. The cable has three audio video plug-ins colored red, yellow and white. Plug them into the TV's corresponding inputs.
Turn on the television and change the input to the same one you plugged the iPod into.
Select the video you'd like to play on your iPod. The iPod's video and audio will be redirected to your television.
Jan 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
Oct 10, 2008 | Denon AVR 2808Ci Receiver
Hyundai plasma model HP-4200
Hello ****, I have the same problem. However. I manage to get the TV on by pulling the cable out and then plug it back in again several times. A couple of times just after you have heard the first click and the a couple of times just when you hear the second click. Sudenly the TV decided to work again. I think it must be a problem with one of the two relays that sits next to each other near the centre of the TV. If you take the back of and then plug the power back in you will see the two lights next to those relays come on and then die out when the relays let go. This is what hapens if the TV doesnt work. If the TV works those lights/LED's will stay green and the relays will hold on and feeding the TV screen. I will probably try to see if I can buy replacement relays and replace these. If I can get hold of them, then probably I would take the existing relays appart to see if I could see any fault. If those relays ar ok and the replacement relays appear in the same manor like the old ones I would look for problems before those relays. Maby order a new circut board from Samsung.
Jan 08, 2008 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
