Sometimes i see 2 flames sometimes i see 1 - Heating & Cooling
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: ruud achiever 90 plus runs threw a few cycles and
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Jan 15, 2011
Unit seems to ignite then cuts out, then blower comes on. Sometimes goes through that sequence and then no blower, does that 2-3 times then light on thermostat saying heater is on stays on but unit does...
If this has an igniter could be flame sensor. Flame sensor tells gas valve that flame is present or it will kick out. Flame sensor should be small rod connected to one wire, and it is on the flame somewhere sometimes opposite end from igniter If you do have sensor turn power off remove sensor and clean If white film on it. I usually clean it with dollar bill
Jan 21, 2011 | Heating & Cooling
I have a gas Frigidaire dryer that heats once or twice
your cycling/hi-limit switch needs to be replaced,it is located on the outside of the burner tube to avoid an overheat condition and cycle the flame according to your heat setting on the control panel
Mar 14, 2010 | Frigidaire GLGQ332A Gas Dryer
Low flame signal, what is a flame sencor and where is it at?
The flame sensor is located on the burner itself inserted into the flame it is sometimes called flame rod about 2 inches long and about the size of a pencil lead. Most of the time this happens it is because of low gas flow or dirty furnace. Check your burners to see if they need cleaning. Rus
Dec 03, 2009 | Heating & Cooling
Furnace has does not ignite flame
how often do you replace your filter?
On the limit switch that protects your unit when it gets to hot the number one reason is dirty filter.
The pressure switch is located in the upper side of cabinet has a rubber hose connected to it. They very rarely go out though. So find your vent fan the first fan that comes on and follow the rubber hose to the switch.
Feb 09, 2009 | Intertherm P3RA-048K Air Conditioner
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
My living flame gas fire has started to have all the flame at one side (side of the pilot light) and sometimes the flame goes underneth the fire? why
a couple things could cause this.
1. you have air flow pushing the flame to one side
2. A dirty burner.
3. A plugged outlet oriface.
Nov 08, 2008 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
