Question about Power Home Security
Replaced networx nx-8v2 control board without programming .On power up both NX -148 E keypads shows system ready to arm for 1 minute then chimes with all 3 zones showing fault. Manual no help !
5 Suggested Answers
SOURCE: Instruction manual for TDK NX-03 CD Sound System needed.
I have a manual if you want to send me your email I'll will scan to PDF and send you a copy.
Posted on Jan 31, 2010
steve_hillin
  • 44 Answers
SOURCE: Can I adjust the volume on my GE Networx NX-148E
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Posted on Mar 05, 2011
AJIN G
  • 6694 Answers
SOURCE: I have GE NX-6 with
hi,
You have to check the fuse inside the system . If there is any power surge happened then there is a chance for fuse become faulty. As you mentioned it would be a power side problem. first of check the fuse inside the system. Also you have to check the 16.5V transformer which provides the working voltage to the sysatem when it is line. If need any more assistance from me then you can contact me through fixya. One more thing is if can add any picture of the cotrol panel circut board then it will be very helpfull.
ok
Posted on Aug 06, 2011
  • 13 Answers
SOURCE: We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Posted on Oct 06, 2012
We have a GE NX-6 alarm system and we had a power surge and replaced the board and the control panel. Now only part of the zones work. How can we fix this?
the eaziest and quickest way would be to install an expander unit but this is not a solution to your problem. did the board you replaced look anything like the one in the picture?
http://www.homesecuritystore.com/productzoom.aspx?Productid=662&imgIDX=3&refresh=yes&ImageFileNameOverride=&SKU=NX-6-FP
if so then it could be that you recieved a faulty board or that one of your pacifes might have been fried and is causing a short directly to your main panel.
Nov 03, 2013 | Home Security
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
Can I adjust the volume on my GE Networx NX-148E keypad?
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
I have a networx nx-12 (d.a.s.) home alarm and the power light is flashing. What does this mean and how do I fix it.
This indicates a low battery condition for the main control panel. Replace the battery in the main control. 12V 4-7AH usually.
Alarmprofessor.com
May 16, 2010 | Home Security
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Home Security Logo
62 people viewed this question
Top Power Home Security Experts
Lawrence Oravetz
Are you a Power Home Security Expert? Answer questions, earn points and help others
