Food saver vac 350 sometimes working,but have to hit the start button several times.
I have a food saver vac 350.I close the lid and have to hit the start button few times before its starting up>The pump is coming right on,even with a first push,but the green light a is not and that's why is not even sealing ever if I don't hit the button until the light comes on.Any idea why is not working properly?
ThaMp3Doctor
  • 8596 Answers
SOURCE: food processor
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Posted on Jan 17, 2009
SOURCE: Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Posted on Apr 30, 2010
rylee_smith
  • 8619 Answers
SOURCE: green clean light wont stop blinking unable to use
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 19, 2010
SOURCE: light comes on. does not process
I borrowed one of these and it didn't work. I had the exact same problem you all are having. The problem? I had the handle pointing to the back instead of the front. Turned the handle around to the front. Presto!! It works..
Posted on Jun 25, 2010
Obertelli
  • 3006 Answers
SOURCE: Shutter Release Button Not Releasing Properly
You have the first signs of a very common problem on all AE-1's and similar AV-1's. Left unattended your camera will soon seize up with the shutter and rewind buttons, plus the advance lever all stuck. The trick to maximise chances of a successful repair is to get it fixed before it totally seizes.
Basically the camera needs a thorough strip down and overhaul. They're well built but fairly mechanically simple so in practice it usually just means that the camera is stripped down, parts cleaned of all dried-out gummed-up lubricants, and then reassembled and re-lubricated. New parts are near impossible to find, but there were millions of these models made so there are plenty of spares donors for most parts. DIY servicing IS possible, but you need to have the right tools, materials and instruction books and the investment for a one-off repair is simply not worth it. You also need to be confident in tackling repairs to precision machinery which may not have been disturbed for thirty years.
Just contact a camera repairer to ask what a CLA service (Clean, Lubricate, Adjust) will cost. In hard economic terms, it makes no sense, but a freshly CLA'd AE-1 in regular amateur use should be good for many more years of reliable service so you can get your money's worth. In the UK the service will normally cost between £60-£100 and in the USA it's a bit cheaper. Demand for camera servicing outstrips availability worldwide as so many repairers have gone out of business, so a common turnaround time is up to six weeks worldwide unless you pay a lot extra for express turnaround as used by professionals who depend on their cameras to make a living.
It's worth getting the camera light seals and buffers replaced at the same time: originals were made of a chemically unstable foam which by now will have turned into a corrosive sticky goo. Higher cost CLA's will include it as standard, lower cost ones will try to charge extra, but I have found that sometimes the shop may do it for free if you point out that you can take the camera elsewhere.
Please take a moment to rate my answer.
Posted on Aug 02, 2010
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
My Rival food saver does not vacuum air out
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
Apr 19, 2010 | Vacuums
Jan 08, 2010 | Tilia FoodSaver V2240
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Need food processor lid
The lid-lip on my small Braun processor broke too, damn things can't handle being accidentally dropped by a fumble-fingered me!
I still manage to work it, I just need to manually hold the broken bit in place (so the safety mechanism lets the motor start), or just use another long thin doodah, like a wooden kabob skewer, to depress the lever. Not elegant, and it means you have to use both hands at the same time (one to activate the pulse button, the other to hold the skewer in place), but it works.
Anyone had any luck supergluing the broken bit back on?
Jan 18, 2008 | Braun Food Processors
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Washing Machines Logo
Top Washing Machines Experts
