Question about Gaggia Coffee Makers & Espresso Machines
RE: Gaggia Titanium. The small coffee button dispenses different amounts of coffee when I choose the ground coffee option.
The amount of coffee that is dispensed is different when I choose coffee beans (press the small coffee button only) vs. when I use ground coffee (press the ground coffee button and then the small coffee button). Is there a way to have it dispense the same amount of coffee regardless of whether I use beans vs. ground coffee?
4 Suggested Answers
JohnnyBeans
  • 223 Answers
SOURCE: gaggia titanium dispenses different amounts of brew
First thing to you should try is descaling your machine if you haven't already. If descaling does not work then it might be some kind of leak issue.
You see, when leaks are present internally in the espresso machine it varies the amount of the cup, because a portion of the water which should have gone into your cup, has leaked into the machine.
It looks like your machine needs some service.
Visit www.CeriniCoffee.com if you need service in the New York City Area.
Posted on Jun 19, 2008
mirran
  • 515 Answers
SOURCE: Saeco digital plus. Grinds beans
try to make a cup of water (Tea) and see if you can get a full cup or just a half.
/Mirran
Posted on Sep 03, 2008
SOURCE: ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
Posted on Jul 31, 2010
Espresso (small coffee) doesn't work anymore
you have to change the amount of the water on the small coffe button. Press and hold it while is making coffee .When you want to stop -just take off your finger from button.
Aug 22, 2014 | Gaggia Titanium Espresso Machine
My gaggia titanium is dispensing very weak coffee. No idea why. Have tried different beans. No change.
try a finer grind coffee , you cant use a "store" grind in a cappuccino machine it requires a much finer grind than that
Dec 07, 2011 | Gaggia Titanium Espresso Machine
Gaggia Titanium - the button for a small coffee has stopped working. Can I do anything to fix it?
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Jun 23, 2011 | Gaggia Titanium Espresso Machine
Too much water is dispensed resutling in a weak espresso. This happened after rinsing the brew unit. Greatful for any assistance with this. I have a 1 year old Titanium.
Hi
Try reprogramming the button that is dispensing to much.
Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn’t fix it, then you might need a new flow meter.
Jul 20, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium, makes hot water but no steam
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Jun 18, 2009 | Gaggia Titanium Espresso Machine
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Dec 16, 2008 | Gaggia Titanium Espresso Machine
Gaggia titanium dispenses different amounts of brew
Jun 19, 2008 | Gaggia Titanium Espresso Machine
Coffe groungs drawer full of water
when you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
Feb 11, 2008 | Gaggia Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
