Can you tell me why the power on my LCD32NK750HDF TV trips as soon as I power on
  • Televison & ... Master
  • 6,694 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 18, 2016
I have a acoustic solution 32inch TV. Model no: LCD32NK750HDF.. It will no longer switch on, we have tried using 3 different power leads but has not worked. Before it stopped working the blue standby
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 22, 2015 | Televison & Video
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
Power surge
There is some shorted component/s at its main power regulator board. That is why the circuit breaker trips as soon as you switch on the set. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 08, 2013 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Whirlpool fridge freiezer keeps tripping power
Does it run for a while than trip the power or does it trip it as soon as it is turned on?
Jan 30, 2013 | Refrigerators
Apex ld3249 shot sparks out and tripped the breaker
A nasty short somewhere or wrong voltage to set---do not keep plugging it in and tripping the breaker--in fact do not plug in at all until a technician examines it(tell him/her what the issue is).
To answer the question here: Dead short on or across the AC voltage line inside the set most likely of primary side of power supply.
Nov 04, 2012 | Apex Digital LD3249 LCD TV
SHUTS OFF AND RESETS MY POWER STRIP
hello the reason for this is 1 of the components has shorted to ground causing the tv to trip the rcd box don't plug in again until the component is found i'd call an engineer as soon as possible
regards
shaun
Aug 05, 2010 | RCA Televison & Video
Genset starts and runs fine but the 30 Amp circuit breaker trips as soon as a load (AC) is applied. Started right up, ran half a day, but now when it starts the minutes I click on the ac the circuit...
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
Nov 01, 2009 | Watts Onan Portable Generator - 4000 ,...
Hello no power set blew out
I'd tell you ,but I have to bill you too...
Oct 01, 2009 | Astar LTV-3201 32 in. LCD Television
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
Power Supply Keeps Tripping Fuse
Freeze the capacitors is a trick worth trying. These usually are the problem
the way you run this is too use freeze spray to freeze each capacitor one at a time . Turn the TV on and if it doesn't trip for a few second longer you know that is the capacitor to change. Freezing capacitors only helps identify the fault if it is a capacitor issue (usually is with power on TV's)
Dec 24, 2008 | Philips 32MF231D Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
