Question about Miscellaneous
My question has nothing to do with microwaves, Can you cook a boiled dinner with a fully cooked shank ham? How long would you boil it?
Bought a shank ham instead of a shoulder, directions say just warm in oven. If I boil it will it ruin the ham?
KOakaKO
  • 135 Answers
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Posted on Aug 09, 2007
  • 12 Answers
SOURCE: Cooks too hot
It would SEEM that this pot has a nanufacturing problem, where the thermal switches, that actually cycle the unit off when it reaches a certain temperature, are faulty...right from the factory. Its common to get a run of faulty thermal units, and is often seen in Coffee Makers.
Posted on Jan 25, 2008
safenude
  • 124 Answers
SOURCE: Have the Nordicware Egg Cooker
Welcome to FixYa! If you are happy with my solution and are able to get what you need, I'd appreciate a rating so that I can continue to improve my service (and make my boss happy). Now to your issue.
Nordicware does not publish their manuals so I am providing you with a number where you can get a users guide mailed to you free of charge.
Call their consumer services department at 1-877-466-7342 8:00am to 4:00 pm CST and we will be happy to send you the directions in the mail.
I hope this solution helps you enjoy your egg cooker for years to come and thanks for using FixYa!
Posted on Jan 30, 2009
  • 36 Answers
SOURCE: the microwave won't boil water or cook the food we
I may need more information, however, I suggest that it could be either a dead magnatron or the high voltage fuse link to the magnatron. Check "Demo" mode, WARNING: if you try and replace the fuse or magnatron yourself, make sure of 2 things, 1/ unplug from the wall 2/ make sure the HV Capacitor is discharged before touching anything around the magnatron....also, I may need the model and brand for better diagnosis... Phil
Posted on May 18, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: We cooking cinamon buns and the whole oven just
It's probably a fuse or thermal cutout (TCO) in the unit.
We have the Advantium service manuals here and here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Dec 26, 2009
804741 model how do I cook a piece of ham in 2hrs
Normally the only way is to reduce the ham in size, cut in to two or three chunks. If it's in plastic not yo worry, wrap each chunk in cling film several times and boil as normal. Don't allow the water to dry out top up regular with hot boiled water. I know it's a late answer but it really works well.
Dec 26, 2017 | Kitchen Appliances - Others
How long to boil a pre-cooked, bone-in ham weighing 10.88 pounds?
I am guessing you are baking or broiling a ham, the amount of time is usually @325F 10-15 minutes per pound. So a 10-11 lb ham would be 1 hour to an hour and a half. Boiling a ham that size would be same amount of time.
Dec 11, 2017 | Kitchen Appliances - Others
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 | Grilling
What is the advantage of steaming your vegetables in a steaming basket?
Steaming is one of the healthiest cooking techniques around. It's also a quick-and-easy way to cook up dinner veggies (especially for my family of 5). Here are some of the best vegetables to steam and tips for keeping them nice and crisp.
The Benefits of Steaming-
You may have heard this before: steaming is one of the best ways to cook veggies so they keep their nutrients. Vitamins are easily destroyed when you cook with water for long periods of time (i.e. boiling), but steaming uses the steam from boiling water to cook your food -- not the water directly.
Another advantage of steaming is no added fat or sodium (do you dab butter in a boiling pot of broccoli or load in the salt?). Any veggie you steam will be around 25 calories per half-cup and chock-full of vitamins and minerals.
Jan 10, 2013 | Home
Whenever I cook pasta the water boils over and causes a terrible mess. How can I stop this happening?
The most common cause of water boiling over when you cook pasta is if you cook it with the lid on the pot. Don't cover pasta fully with a lid. Either cook it uncovered or if you are in a hurry to cook it quicker, just partially cover the pot.
Also make sure you don't overfill the pan with water as this is another cause of overboiling.
Jan 10, 2013 | Cooking
I have had 2 microwave ovens they both leaked water from the door while cooking,when nothing boils over,no mater what i cook
That is not normal, a test should be done to check microwave leakage to make sure numbers are within safety limits.
Apr 21, 2012 | Emerson MW8889SB Microwave Ovens
My bravettii slow cooker would not cook baked beans they cooked for 18 hrs total 6 hrs was on high and 12 hrs was on low and the beans are still not fully cooked it never came to a boil is there...
I can't solve your problem but I can sure relate. I am having the same problem with my Bravetti Pro (it's far from Pro - it should be called Bravetti Amateur) I tried cooking a small ham with cut up potatoes recently, and after 11 hours cooking at the medium setting, the potatoes were not cooked. I got this thing as a gift about a year ago, and although I've only used it a few times, it never seems to cook properly. Mine was purchased at Canadian Tire and although I don't have a receipt, I think I'll try to take it back. Good luck with yours!
Tom
Feb 08, 2011 | Bravetti PC107HA Slow Cooker
New sanyo microwave, steam or smoke coming out when cooking from 1 minute
Steam is OK as it means whatever is in there is boiling furiously, it may need turning off at that point!
Smoke though means it has gone too far. Check the cooking times used and the recommended cooking times on the packet along with the adjustment for the power of your oven.
Jan 13, 2011 | Sanyo Microwave Microwave Oven
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
A dinner I was cooking in the microwave sprayed on the inside like an entire covering and I can't remove it.
Ahh, I hate when that happens!
Put a microwave safe bowl with about 3 cups of water in the microwave and heat on high for about 4 minutes or until boiling well. leave it sit for several minutes and then wipe out the inside of the machine with a damp cloth or sponge. You are not alone:)
Farmerbear at FixYa.com
Sep 15, 2010 | Emerson Microwave Ovens
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
