I need a new handle for my fireplace it is a Fabco pioneer Z 1988 modle
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
Muskoka electric fireplace ,the switch doesnt work
  • Unplug the fireplace
  • Open up the fireplace to gain access to the inside.
  • Inspect switch for charring, melting, etc.
  • Inspect circuit board for charring etc.
  • If indeed the switch is the culprit: then...
  • Unhook the wires from the switch.
  • Remove the switch.
  • Bring the switch into your local hardware store or radio shack.
  • Buy a compatible switch - pay attention to amperage markings etc. so your new switch can handle the power.
  • Install new switch and re-hook up the wiring.
  • Close up the fireplace and enjoy...
Nov 25, 2012 | Heating & Cooling
1988 Pioneer, windshield wipers, heater blower, directional signals, radio work intermitantly. Jiggling, the ignition switch at the columun sometimes clears the problem, sometimes it does not. Is the...
Sounds like you need a new ignition switch. It is either attached to the key cylinder or down towards the bottom of the column, under the dash. It may just be loose, or needs adjusting.
Aug 25, 2011 | 1988 Jeep Cherokee
Frigidaire modle ffu21f5hwb door handle loose how
Pop out the screw hole covers and tighten the screws.
Sep 16, 2009 | Frigidaire Freezers
Marco fireplace Model 794 cant light the pilot
the valve handle is on when the handle is in line with valve body, off when crossed...are you pushing in on the pilot gas valve under unit? if not.. open bottom panel.. turn knob to pilot..push and hold down while sparking..if pilot lights continue to hold for about 60 secounds.. then release knob and turn to on! Also FYI... these units have a vent recall on them! please go to google and type in your heater, then model #
Mar 25, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Need help in wiring an after market radio in 1988 jaguar
Are you sure the radio itself is in good working order,dont want to seem patronising but should always start with the new part (what ever it is ) as a process of elimination
Mar 09, 2009 | 1988 Jaguar XJ6
Replacing an interior door handle
first remove the door panel after you have completed that remove the 3 bolts holding the handle in place, pull the handle out on the reverse side there will be a connecting rod with a retainer clip holding the rod to the door handle remove the retainer clip and rod and remove the broken handle follow instructions in reverse to reinstall new handle
Jul 19, 2008 | 1988 Ford Taurus
Problems conecting to pioneer reciever
You will need a 1-to-2 AV Y-adapter. One end will plug into the headphone jack of your mp3 player, and the other end will plug into the red and white audio input of an open slot on your Pioneer receiver. Then change the mode on your Pioneer receiver to correspond to the input jack that you are using. If you plug the Mp3 player into AUX, change the pioneer mode to AUX, etc.
Jun 20, 2008 | GPX MW3837 MP3 Player
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Plasma TV
Can you describe the more symptoms?
Oct 12, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
