Question about Dryers
No power to becko sensor dryer plug in fuse is fine
My becko dryer stops working when half way through the cycle the plug is plugged into an extension lead and the dryer plug gets warm then switches off please help only 16 months old
FIRST OFF U SHOULD NEVER USE AN EXTENSION PLUG ON A BIG APPLIANCE ITS A FIRE DANGER. HENCE THE HOT TO TOUCH.
YOU MAY HAVE BAD MOTOR WINDINGS OR DOES THE MACHINE START RIGHT BACK UP AFTER SWITCHING OFF IF NOT, THAT IS A SIGN OF BAD MOTOR WINDINGS.
Jan 02, 2017 | Dryers
Asko 12505 has no power
i assume you checked the fuses with a meter?how old is the unit?
Sep 16, 2007 | Washing Machines
Dryer was running and then suddenly stopped. I have checked the power breaker and it is fine, light is on in the machine, and there are no issues with the plug. When I opened the door it was very warm...
check and see if it has blown either of the 30 amp fuses supplying the 220 volts. More likely the duct heater sensor. Small sensor connected by small wires on the air duct found after you remove the front panel.
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Neptune dryer proble. The dryer works except no heat. Flame starts, but then turns off. Igniter element was checked and is good. What else should I check in order of probability? - flame sensor? -...
Hi
Thanks for using FixYa. Things that could stop an electric dryer from heating: - house fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer turns on briefly, then does not keep going. belt is fine and also manually turned to see if it was a reset. after turning on it dies...then after turning on nothing at all. power to motor is fine and...
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing
Jan 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Miele T358C Dryer Blew up!
it could be a shorted heating element a shorted to the case, motor start capacitor, or a defective motor ,f i would inspect the first two items closely
Sep 20, 2009 | Miele Novotronic T240 Electric Dryer
Kenmore dryer
Hi!
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Do rate the solution as FIxya if you find this solution helpful.
Thanks
Rylee
Mar 15, 2009 | Kenmore Dryers
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Maytag Gas Dryer SDG515DAWW - heating stopped
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
Jan 03, 2009 | Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
