Question about Cutter Tools
Changing knife blade - Cutter Tools
2 Suggested Answers
cargurudude
  • 26 Answers
SOURCE: stanley knife blades fell down drum and under
Probably the best thing to do in this situation is to empty the washer out, then unplug it and turn the water off at the spigot.
Then invert the washer, leaning it back, so as to reach the blades under the drum.
Posted on Mar 04, 2009
Tip
How to choose the right knife for your camping trip
depending on what your plans are for the uses of your knife you will first want to pick either a folding knife which are smaller and can be put in your pocket easy to carry then you have nonfolding knifes that have sheifs which need to be on a belt or put in a backpack pocket there bigger then a folding knife and thicker blade then a folding knife a non folding knife are mostly more stable then folding knives you dont have to worry about the blade folding down on you fingers but most folding knifes have a blade lock just remember when choosing your knife make sure its comfortable to use and not to big bigger is not always better and dont forget a good sharping stone when camping your knife is your life
on Jul 24, 2012 | Camping, Backpacking & Hiking
How to change stanley 99E blade
Hello, Go to this youtube website too see video on changing the blade.
Jan 01, 2014 | Stanley Bostitch 10150 Straight Handle...
I can not get the blade out of my dewalt retractable utility knife dwht10046
Just take apart the knife and get knife out reassemble it and then put the knife back in
Nov 23, 2012 | Dewalt Tools & Hardware - Others
How to sharpen the blades on my Swiss army knife?
You can sharpen your Swiss Army Knife is using a circular motion. Start by holding the blade away from you at the proper angle. Run the blade of your Swiss Army Knife in a clockwise motion on the stone until you have sharpened that side of the blade. Turn the blade over and repeat with a counter clockwise motion.
Jul 09, 2012 | Camping, Backpacking & Hiking
How do I change the blades on a vermeer 1600A chipper
Place the chute over the rotor. Remove all the clamp bolts for one blade. This will allow you to remove the old blade and clamp bar. Clean clamp bar and blade slot. Install new blade with clamp bar. You will need a knife gauge for this. Use the knife gauge at each end of the blade. Torque clamp bolts to 280 ft. lbs. After blades are installed it is necessary to adjust the bed knife by loosening the three bed knife bolts. Use the set screws to adjust the bed knife to 1/16 in. above the lower feed plate. Torque the bed knife bolts to 250 ft. lbs. Then use the other two bolts to adjust the lower feed plate to .013 to .016 between the bed knife and the rotor blades. Put the chute back into place and you are good to go.
Dec 08, 2011 | Garden
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
Jul 13, 2011 | Stanley Fatmax Xtreme Retractable Utility...
How do I change the blade on a Stanley utility knife, 10-788?
Hi, W/D here.
The blade changing is accomplished by pushing the yellow button and pulling the old blade out. It is reversible. If there is no blade at the ready, there may be more in the body of the knife, which are located behind a swing out panel on the handle. You'll need to push in the yellow button when installing the blade, and once the blade is in, release the button, and moge the blade until it clicks in place.
--W/D--
Jan 21, 2011 | Stanley Garden
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Cutter Tools Logo
882 people viewed this question
Top Cutter Tools Experts
Are you a Cutter Tool Expert? Answer questions, earn points and help others
