Question about Miscellaneous
Can you make boiled dinner with fully cooked shank ham?
5 Suggested Answers
  • 653 Answers
SOURCE: How to heat a bone in spiral ham
You could heat it on low power in the microwave at about 50% power for about 10 minutes, let it sit for a few minutes, check the temp around the bone, and do it again for another 2 minutes at a time until it gets to whatever temp you prefer. If you do use the roaster, put a cup of water in the pan, cover the ham, and heat at about 300 for about 30 minutes. If you want a little variety, instead of water you could pour a cup of Coke or pineapple juice over the ham, then cover and heat as noted above.
Posted on Apr 16, 2009
  • 274 Answers
SOURCE: When I was cooking dinner and went.. when I was
did the clean lock get pushed to lock it ,let the oven cool down and it well unlock. it should open at about 100 degrees
Posted on Jul 26, 2010
  • 6771 Answers
SOURCE: Cooking with metal probe not
Unfortunately when the metal probe was inserted in the ham it caused the magnetron to arc to the probe causing it to short out, but usually the thermal fuse will open and shut the system down preventing damage. It usually takes 30 to 60 minutes for the fuse to reset and allow the microwave to run, try heating water! if you are lucky the oven is unharmed. But if there no change the magnetron will need to be replaced which probably would not be cost effective, cheaper to buy new unit.
Posted on Mar 07, 2011
Testimonial: "Thanks...very helpful...."
SOURCE: Can a fully cooked Cure 81 ham that has frozen then thawed and warmed-up be refrozen?
Yes It can be, the textures will keep on changing the more you do it.
It is preferable that you divide any cooked or uncooked food to the portions that can be consumed in one time, before freezing, this will maintain a better taste and texture.
Posted on Feb 03, 2015
How long can you keep a fully cooked ham in the refrigerator before it spoils?
Hello, Linda -
According to the U.S. Department of Health and Human Services website on Food Safety, the following are the safe refrigerated storage periods:
- Cooked Ham, vacuum sealed at plant, undated; unopened: 2 weeks
- Cooked Ham, vacuum sealed at plant, dated; unopened; Use by date
- Cooked Ham, whole, store wrapped: 7 days
- Cooked Ham, half, store wrapped: 3 - 5 days
- Cooked Ham, slices, store wrapped: 3 - 5 days
Source:
https://www.foodsafety.gov/keep/charts/hamstoragechart.html
Jan 19, 2018 | Cooking
Can I freeze a cooked ham
Yes you can. you can freeze anything once it has a cooking process to kill bacteria. My advice would be to slice it and wrap it in greaseproof paper or baking parchment and then pack it in 'sandwich portions'. You can also serve the slices hot with parsley sauce as a dinner meal.
I am a trade chef and caterer. :>)
Jan 03, 2018 | Kitchen Appliances - Others
804741 model how do I cook a piece of ham in 2hrs
Normally the only way is to reduce the ham in size, cut in to two or three chunks. If it's in plastic not yo worry, wrap each chunk in cling film several times and boil as normal. Don't allow the water to dry out top up regular with hot boiled water. I know it's a late answer but it really works well.
Dec 26, 2017 | Kitchen Appliances - Others
How long to boil a pre-cooked, bone-in ham weighing 10.88 pounds?
I am guessing you are baking or broiling a ham, the amount of time is usually @325F 10-15 minutes per pound. So a 10-11 lb ham would be 1 hour to an hour and a half. Boiling a ham that size would be same amount of time.
Dec 11, 2017 | Kitchen Appliances - Others
Had a fully cooked ham and heated it up with the dressings for it. can tjis ham be frozen
hi Verene.
If you have leftovers, you can easily store ham in the refrigerator for up to a week. However, if you have a lot, or even a whole cooked or smoked ham left untouched, youcan keep it in the freezer for longer storage. ... 2 Place your sliced or cut-up ham into airtight freezer bags.
How to Freeze Cooked & Smoked Ham - Living The Bump
living.thebump.com/freeze-cooked-smoked-ham-7911.html
Can you freeze a cooked ham?Experts recommend freezing uncooked, uncured and fresh ham for 6 months or less. If the ham has already been cooked, it should be frozen for 2 months or less. If you plan on freezing a ham for more than a couple of months, you should buy it uncooked, put it in the freezer and then thaw it when you are ready to cook it.Can You Freeze Ham - Dereezedereeze.com/food-and-cooking/can-you-freeze-ham/Search for: Can you freeze a cooked ham?
if you need to read up some more then go to this link.
CAN COOKED ham be frozen Google Search
Nov 25, 2017 | The Kitchen Appliances - Others
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 | Grilling
What temp and how long to cook a 10 lb ham in a turkey frier?
12-17 minutes per pound at 375 is recommended for an oven. I'm not sure of the difference between the frier and oven. Most prepared hams are fully cooked or smoked. Here's a link to check other info on cooking hams.
http://www.bettycrocker.com/how-to/tipslibrary/cooking-tips/how-to-cook-a-ham?utm_source=Email_newsletter&utm_medium=email&utm_campaign=BC_12_23_2016&vcode=AQAAAABFsdYhKGypebKYiGtyMEVUHdxcQGJZky68gCbk2ZRXpAh84Fo6UreMNu2noN699yr-uZMq-s5WshjGdi7heKqVYFWyADXTRxPbFUM4Wf8JXA
Dec 25, 2016 | Grilling
How long to heat a fully cooked ham and what temp
Preheat the oven to 325°F. Place the ham on a rack in a shallow roasting pan. For a whole 10- to 15-pound ham, allow 18 to 20 minutes per pound; for a half--5 to 7 pounds--about 20 minutes per pound; or for a shank or but portion weighing 3 to 4 pounds, about 35 minutes to the pound.
Nov 26, 2015 | Hearthware Home Products Nuwave Pro...
How to cook pinto beans in my 22 quart roaster oven
I cook 140 lbs of beans every year at church for a ham & bean dinner. I soak them overnight in 4 large rubbermaid containers (about 35 lbs in each covered all the way to the top with cold water). In the morning I drain the water, rinse beans and divide between about 14 cookers (several of them are the 22 qt roasters). You can put beans in to about 1 1/2 to 2" of the top rim. Put a ham bone in (I pre-cook about 12 10 lb bone-in hams two to a roaster sitting in about 1" water several days before, chop the meat, save the juice and the bones) and a cupped palm full of salt (3/4 to 1 T ?) and cover with water. Cook on about 350 degrees. When they start going dry add the leftover ham drippings that were saved (I usually have it heating in a crockpot nearby so that it doesn't slow the cooking of the beans down).
Aug 10, 2011 | Rival 18 Qt Roaster Oven with Buffet...
Miscellaneous Logo
19 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
