Question about Vacuums
Only the big brush spins and the little one doesn't. Can turn by hand. Can't figure out what's wrong
reddevil6
  • 1673 Answers
SOURCE: suction?
You won't feel a great deal of suction like you tried to do it. But look at the fan, if it isn't worn down, and the bag fills with air when you turn it on, then the suction should be ok. If you haven't changed your belt in awhile, I am sure that it is stretched and is having trouble turning the brush roll.
Posted on May 21, 2008
SOURCE: Bissell 9200 Proheat 2x carpet cleaner
cleaner will not start
yes, I plugged it in!
Posted on Nov 24, 2008
SOURCE: We are trying to replace
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
Posted on May 22, 2011
  • 240 Answers
SOURCE: The brushes won't spin. I
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Posted on Jun 28, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: brush inside main head doesn't spin, and stops
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 12, 2011
    Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
    Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
    Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
    We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
    May 22, 2011 | Vacuums
    The turbo brush attachment on my bissell cleanview helix suddenly wont spin. I bought this vacum a month ago. there is nothing wrong with the vacum otherwise.
    The turbo brush may just need to be cleaned. If hair or other large debris gets wrapped around the brush, it can prevent it from spinning. Since the top of the turbo brush is clear, you can look in and see if there is a lot of hair wrapped around the brush. If so, you can open it up by removing the two screws on the bottom of the brush and popping the clear cover off, then cleaning all the debris from the brush (scissors work well if its hard to get dog hair off). Be careful to see how the brush goes back together as you take it apart.
    If cleaning the brush doesn't fix it, the belt might be broken. As you're looking at the top of the brush, there is a little belt that goes from the brush itself to the large blue/green gear (it's red on some models) so that if you reach your hand in and turn the gear, the brush should spin. If this belt is broken or missing, it will need to be replaced. You can probably find a replacement belt online, or you can order a whole new turbo brush from the Bissell website for $24.99.
    Feb 04, 2011 | Bissell Cleanview Helix Deluxe Bagless...
    Brush is not spinning
    Most likely the brush is frozen in place. Remove the brush and clean well, making sure the end pieces that hold it in place turn freely. Spray a little WD40 where the axle meets the end pieces and turn by hand to be sure they spin without problem. Reassemble making sure the belt is on properly so that the brush turns in the correct direction. If by chance the belt is broken, now is the time to replace it.
    Sep 15, 2010 | Vacuums
    Why wont the brush turn on my capret cleaner i replaced the belt
    Sep 14, 2010 | Vacuums
    I have a bissell easy vac and the metal part that spins the rubberband and brush keeps overheating and burning all the belts I replace. What should I do?
    Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
    Sep 13, 2010 | Vacuums
    My bissell helix cleanview vacuums brush doesn't spin
    Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
    Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
    The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
    Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
    Brush won't spin. Put it back on the ribbed belt
    Make sure the driving motor (power on) is turning (without the belt attached). Make sure the brush turns freely when the belt is off (it's probably jammed with wound-up hair, thread, and other debris--remove the brush and clean/lightly oil the bearings). Check the tension of the belt which should be fairly firm--replace if sloppy. Rotate the motor shaft by hand when everything is back together and make sure the brush can be driven without the belt trying to jump off. Hope this helps!
    Mar 03, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
    No spinning.
    Most common problem when the brushes stop spinning on this model or any "SpinScub" model is that screen filter is clogged as suggested above. If that isn't your problem then likely the turbine has gone bad. Some genius at Hoover designed a metal gear to drive a Nylon gear (Inside the black part that says "Assembled in Mexico". If the brushes jam hard and sudden, the metal gear just shaves the nylon right off. Solution: You will need a new turbine unit. Cost for the part is about $36, installation takes about 15 minutes (about 6 screws and two tubes).
    I refurbish and repair vacuums and steam cleaners for a living and see this all the time.
    Jun 23, 2007 | Hoover SteamVac F5914-900 SpinScrub...
    Vacuums Logo
    21 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
