Question about Brother HL-4040cdn Color Laser Printer with Duplex and Networking
I have horizontal streaks/smudging on BACK of paper w/Brother HL-4040CDN. Suggestions?
Soulvisitor
  • 1113 Answers
SOURCE: Paper Curling with Brother HL-2040
Replace fuser assembly/have fuser unit replaced if you have tried fresh quality paper from a unopened ream. The first versions of these had the fuser and exit assembly modified by brother to help eliminate excessive curl last 9 digits of serial number are higher than D5J760210 have already been modified, if lower ie D4Z99999 need to get mod. fitted.
Posted on Jan 10, 2008
ebackhus
  • 31 Answers
SOURCE: Toner smudges along the extreme right side of the paper
If the smudges are gradually fading then it's likely just excess toner hitting the fuse drum. Try a few cleaning cycles/test prints and see if that makes it go away. If not, see if you can get a replacement toner.
Posted on Jan 05, 2009
  • 83 Answers
SOURCE: I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Posted on Nov 13, 2009
n25an
  • 622 Answers
SOURCE: black lines down side of paper on HL-5370 brother laser printer
you have a bad drum... it needs to be replaced
Posted on Dec 27, 2009
  • 270 Answers
SOURCE: my lamp "paper" blinkikg brother hl-2030
Remove the Toner Drum unit and look for a little blue tab. Slide it back and forth a couple of times to clean a corona wire and see if that helps.If the problem still exists, you may try this 2nd option.
> the front door. There is something wrong with the front door, or the mechanisms that signal that it is closed. Closing the front door (the one that you open to pull out the toner and drum) all the way to where it snaps into place then the paper light flashes red. However closing the front door to the point where the "ready" light comes on (don't snap the door into place, just close it and let it rest in place without snapping it closed) and the printer prints fine, pulls paper from the tray and prints like it should.
So give it a try, don't snap the front door all the way closed to where it snaps closed, just close the door to where it's resting closed to where the ready light comes on and see if this helps you.
Posted on Nov 20, 2010
What is the cause of problem where my printer (HL 1440) prints with black smudges & streaks of ink on the paper.
sounds like a possible problem with possibly the drum or the transfer belt. trying a different toner cartridge may fix the problem but it may not. Most likely given the cost of repair, replacement may be your best option.
thank you,
Lee
Jun 09, 2011 | Brother HL 1440 Laser Printer
Just installed a new toner cartridge and I'm getting 3 horizontal smudges (feint traces of the first line of text in each smudge) any suggestions?
you may have put a scratch mark on the drum. take the toner out and manually rotate the drum and see if you can find the same smudges.
Aug 25, 2010 | Brother HL 1440 Laser Printer
My brother 4040CDN printer (which I got yesterday), is now printing with spots all over the page. Any suggestions?
Take it back ... dont jeopardize your standing as a new customer with a new machine that may be faulty.
May 02, 2010 | Brother HL-4070CDW Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Model HL-4040CDN, told me to change magenta toner
Have the same problem, can't find the solution. Filed a complaint on the brother website feedback link, hopefully they will resolve if more people post problems with toner cartridge changes
Nov 10, 2009 | Brother HL-4040CN Laser Printer
BIG BLACK STREAK ON PAPER
If you're experiencing horizontal streaks, and already tried changing cartridges but that don't help, look in the bottom of the paper tray. If that small metal ground terminal gets ditry or bent, that could be the cause.
May 08, 2009 | Brother HL-2070N Laser Printer
Brother HL 1440 Laser printer-horizontal black streaks
check your drum may the corona ware is broken . change the drum.
Feb 27, 2009 | Brother HL 1440 Laser Printer
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
Jan 05, 2009 | Brother HL 5250DN Laser Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
Brother HL-4040cdn Color Laser Printer with Duplex and Networking Logo
47 people viewed this question
Top Brother Computers & Internet Experts
edy copier
edy copier
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
