Question about Miele Coffee Makers & Espresso Machines
Miele 4065 Drip Tray note still showing on-I have cleaned everything. Power on and off, cleaning contacts, sliding the drip tray differently. No clear buttons to push nor reset.
  • 74 Answers
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Posted on Jul 15, 2008
SOURCE: Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Posted on Mar 05, 2009
  • 60 Answers
SOURCE: Empty Drip Tray message
Try to clip off the tray contacts and clean behind them. If they are dirty and wet on the backside the machine will keep asking you for Empty tray. Use a small screwdriver and clip them off from the inside of the tray
Posted on Aug 20, 2009
burdfrenzy
  • 348 Answers
SOURCE: How do I find and clean my drip tray in my admiral
First thing unplug the unit. Then take off the front bottom grill. It should be behind there. You need to get on your hands and knees and be eyeball high with a ant using a flashlight. While your down there get the vacum cleaner out and **** out all of the dirt collected on the cooling fins. Use a crevice tool for that and be gentile. Hope I helped you.
Posted on Oct 17, 2009
  • 323 Answers
SOURCE: Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Posted on Oct 31, 2009
I have the Miele 4066. I ran the descaling program. When it was finished it read a message that it didn't run properly to run again. But it gets stuck on empty drip tray mode. I even unplugged it
Take out drip tray and inspect the 2 contacts at the rear. Clean these and surrounding area. Also inspect the contacts at the back of the tray slot to see if these are also dirty. Then re-try. Hopefully this will fix the problem. Regards
Apr 20, 2017 | Miele Coffee Makers & Espresso Machines
I have a message: Empty the drip tray, but when I empty it, i still get the same message and the machine will not respond to any arrow inputs, so, I can't make any drinks
I have never had seen this problem ... however assuming the tray contacts are not shorted in any way ... its likely to be a problem with contacts in rear of the tray cavity. I would check the following;
1. Remove drip tray and shine a torch into the tray cavity to inspect the receiving contacts that accept the tray contacts. Perhaps theses contacts are shorted in some way.
2. The next step is to open up machine, but you need to be suitably experienced with electrical appliances to perform this step. Disconnect the power at the outlet (or if this is not accessible than at the fuse box). Remove the machine from the cavity and remove the rear panels (making note of which screws go where). Locate the wires that terminate on the contacts on the rear side of tray cavity. Disconnect the wires from these contacts. Replace panels and then reapply power to unit. If this solves your problem .. then there must be a short on the contacts in rear of tray cavity. If this does not solve the problem then trace this wire back to control board and remove wire at the control board. Again replace panels. If this solves problem then there must be a fault in the wire which can be fixed/replaced.. If this does not solve the problem then it would appear to be a problem with control board and best to call Miele.
Please come back if you need more help and also once you solve the problem .. to explain what went wrong. regards
Apr 20, 2015 | Miele CVA 4066 Stainless Steel
Drip tray error
Joe -
Try removing the tray and drying the contacts on the back of the tray with a towel. Once dry take a pencil eraser to them and clean them throughly.
Put tray back in and test.
Hope this helps
Dec 07, 2013 | Miele CVA 4066 Stainless Steel
I have a Miele coffe maker and its stuck on empty the drip tray cycle....cannot recognize that the drip tray has been emptied. How can I get out of this mode.?
I just posted this solution in another model.
I have a Miele CVA 4085 built-in coffee maker which had a similar problem to this and other problems where it gets locked into a state where it demands you empty the drip tray even though it is empty. In my case it was at the end of a cleaning cycle and refused to go on. Cutting power and restarting always had it return to the same state: Cleaning, empty drip tray.
I cleaned the contacts on the drip tray and at the back using the nail file, still nothing. Then I found a post on how to get into the programming menu, which on the CVA 4085 is this:
  1. Open the door and switch off the power with the rocker switch on the top left.Wait at least 5 seconds.
  2. Switch the rocker on then VERY QUICKLY close the door and hold the clear button for 5 seconds.
  3. With your other finger touch the ON button then pull both fingers away at the same time.
  4. Do 5 rapid presses of the clear button but hold your finger down on the last press and keep holding it down until the programming menu comes up.
  5. Do not press the reset button that you see at the top of the menu (unless your German is quite good or you have access to Google Translate).
  6. Scroll down until you find the reset cleaning button and select it. Once you have confirmed you can then exit programming mode by powering off.
It took me quite a while to get to this point, but at least I can now recognize the German word for drip tray.
Jan 09, 2013 | Miele CVA4070 Coffee Maker
I have a Miele Coffee System CVA 4075. Kept getting fault 73 message. Long story short, the Brew unit is out of place. I somehow need to get it back into the basic position. When I turn it on now it reads...
I have a Miele CVA 4085 built-in coffee maker which had a similar problem to this and other problems where it gets locked into a state and won't let you do anything else. I my case it says Cleaning and it demands you empty the drip tray even though it is empty. In my case it was at the end of a cleaning cycle and refused to go on. Cutting power and restarting always had it return to the same state: Cleaning, empty drip tray.
Oct 07, 2012 | Miele CVA615 Espresso Machine
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
Miele 4070 watersystem fault but the catch tray has no water so it's not overflowing. What might this be?
it is leaking internally. When the drip tray is full, it tells you to empty the drip tray. when the machine has a problem and develops a leak, it locks up and displays watersystem fault. contact miele at 800 843 7231 and they can put you in contact with a service center in your area.
May 25, 2011 | Miele CVA4070 Coffee Maker
I have a Miehl cva4070. My problem is twofold. 1. The unit seems to have lost its ability to recognize that the Drip Tray has been emptied. I have turned it off and back on, unplugged and restarted,...
take a long fingernail file that is a fine grit. hold it with a pair of needlenose pliers, and use it to clean the contacts in the back of the machine where the drip tray plugs in. You need to clean each contact top and bottom. you can tape the fingernail file to a ruler or pencil or whatever you need to so that you can reach the contacts. it is very tight as the opening is only an inch or so tall. dont go crazy with the file, just lightly touch each contact. also you can swap the two metal contacts on the drip tray. you will notice that they have little wear lines on them that are in different locations. if you swap them , they will be exposed to new surface. if that doesnt work, you may have an internal leak that is shorting the drip tray contacts from the back of the machine. If there is water back there, it is the same as the drip tray being full.
Apr 22, 2011 | Miele Coffee System
Oct 31, 2009 | Miele KF7642S Bottom Freezer Refrigerator
Aug 17, 2009 | Franke Saphira Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
