Audyssey no bass. Please advise - Audio Players & Recorders
Screen moving in and out of focus regardless of input or settings
Fault to its T'Con board. Replace it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2015 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
How do I reset after overheating
It's getting to hot.
Needs a cooling fan.
Too many speakers or too high a volume.
Let it cool. Should restart.
If you unplug it,you will lose your presets.
Nov 11, 2014 | Marantz SR7008 A/V Receiver - 9.2 Channel...
Power surge on my Toshiba 50L4300U and now no sound. I do have picture
Check fuses and breakers on Polk.
If they are ok then take it to the shop.
Mar 30, 2014 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
I'm about to hook up my KLH to an Onkyo Receiver with Audyssey sound features. 2 questions: it asks me to set my sub to 75 DB. Since my volume dial goes 0-10, which number maps to 75 DB? Also, what...
I think it wants you to raise the volume high enough on the sub so IT can hear at least 75dB. It can always adjust the sub downward if necessary. Max it out at the sub and let Audyssey deal with the adjustment.
Your crossover frequency selection would be a piont below which you want the sub to activate. It depends on the bass capabilities of your other speakers. You want some overlap so there's no droop in the crossover region where your main speakers roll off.
Jul 13, 2011 | KLH ASW10-120 Subwoofer
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
Audyssey vs Direct switching on Onkyo SR606
Audyssey is the licensed feature this receiver uses for room and dynamic equalization. It sounds like the Audyssey process is activated. The manual says the Audyssey indicator "flashes during automatic speaker setup".
Has this unit ever worked or are you still setting it up?
Feb 09, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 bass treble settings seem to make no difference
I ran into the same issue and was stumped at first. Then I noticed somehow I had changed the sound processing to "Direct" which meant the signal coming from the source was bypassing all of the control in the receiver. All I had to do is select another option (press stereo for example on the remote) and kick it out of the direct mode.
Dec 21, 2008 | Onkyo TX-SR606 Receiver
Onkyo 875 Audyssey will not detect
no solution from me but just to say i am having exactly the same problem - did you get anywhere with yours?
Jul 10, 2008 | Onkyo TX-SR875 Receiver
22 people viewed this question
 Grubhead
Grubhead
