Question about Honeywell Heating & Cooling
Honeywell tower ceramic space heater stops then lights blink
  • 4 Answers
SOURCE: Honeywell Compact Quick Heat Ceramic heater with tilt feature - HZ 325
Your prob is their is a thermostatic solinode that is trigger the unit to go off--because it thinks itself as too hot and unsafe to be on--this trigger was defective or damaged by disuse and/or fatigue------give it a shake-- better yet, when cool and unplugged-vacuum or blow out with compressed air-with out disturbing integrity of workmanship on device--if that no worky--time for new one---thermostatic element is dirty, device being of differing Mghz than outlet, if fairly new device--amperage of outlet is too small for device to work properly. If it is a 240 volt or a 120 volt device and your attempiting to use the wrong voltage outlet--STOP USING THE DEVICE
Posted on Jan 21, 2008
Dr Fly
SOURCE: honeywell ceramic heater hz341bl
Like most heaters, this Honeywell ceramic heater has a tip switch designed to turn the heater off if it falls over. Unfortunately, all you need to do is bump the heater and the switch can open. Sometimes the switch will stick and the heater won't come on even when it is upright—sticking during storage could easily happen, particularly if not stored upright. When the switch is stuck on my heater, when I try to tturn it on the yellow and green pilot lamps flash once but nothing happens.
The solution is to rattle it, shake it, and invert it a few times to unsitck the switch. It always works for me. Something probably best done before you get frustrated to the point of shoving it through the floor. Also, if the heater was running when the switch sticks, be sure it cools down so the thermal switch has a chance to come back on.
Posted on Aug 26, 2008
SOURCE: Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Posted on Nov 20, 2008
SOURCE: How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Posted on Dec 01, 2008
SOURCE: I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Posted on Nov 18, 2009
Honeywell portable heater HCE322V manual
Honeywell has the manual for the HCE322V ceramic tower heater on the product page: http://www.honeywellstore.com/store/products/digital-ceramic-tower-heater-hce322v.htm . Click on the Manuals tab. The direct link to the manual is http://www.honeywellstore.com/store/images/pdf/HCE311-HCE322-HCE323-honeywell-heater-manual.pdf .
I hope this helps. Note: the manual covers a few different models. You should ignore any section about the HCE323; that model has a remote and a few other extras.
Jan 08, 2017 | Honeywell Heating & Cooling
Can I purchase a new remote for an unidentified heater?
Heaters : Target
www.target.com/c/heaters-home.../-/N-5xtuk
Target Corporationheaters buying guide > ... (125) reviews for Lasko Tower Heater with Electric Control ..... (23) reviews for Lasko Digital Ceramic Tower Heater with Remote.
Lifesmart Meduim Room Infrared Heater w/Remote - Space ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Lifesmart Meduim Room Infrared Heater w/Remote - Space Heaters. ... This compact heater also includes a new larger remote control to operate the ... the best heater I have ever owned for my purposes and would definitely buy ...
Heaters - Overstock Shopping - The Best Prices Online
www.overstock.com/Home-Garden/Heaters/.../subcat.html
Overstock.comBuying Electric Heaters: Tower heaters: Tower heaters are ideal for many homes .... Lifesmart Slimline Compact Infrared Heater with Remote Today: $102.99 4.4 (10 .... Dyson AM09 White Hot + Cool Fan (New) Today: $449.00 $499.99 Save: ...
Jan 27, 2016 | Heating & Cooling
I'm searching for a Honeywell HZ365 ceramic compact heater to purchase
this one is similar...
http://www.amazon.com/Honeywell-50250-S-99-97%25-Round-Purifier/dp/B00007E7RY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1354484907&sr=8-1-fkmr0&keywords=Honeywell+HZ365
Dec 02, 2012 | Honeywell HZ365 Ceramic Compact Heater
The heater no longer moves from side to side. It's an oscillating heater. How can I fix this?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Oct 05, 2010 | Honeywell HZ370 Space Heaters...
Hi, Honeywell (HZ-341BL) Ceramic Heater stopped working. Can i get help
when most ceramic room heaters stop working, the blower is clogged with lint and dust from floor use . get an air compressor, or a can of air. take unit outside using a small head philips driver remove screws while laying on an old sheet .disassemble cover carefully and blow dust away from you and clean blade without bending with a toothbrush in vinegar water not gettting any liquid on the electrical parts. reassemble. thanks karl
Dec 14, 2009 | Honeywell (HZ-341BL) Ceramic Heater
Cz 446 comfort zone ceramic heater shuts off
Hi, the problem you are having is the thermostat control, and dimming the lights is a indication of the neutral side of the control if faulty.It is drawing enough amps to make you're home lights blink, so I would stop using it now and if you are inclined to replace this control yourself I would. If this is something you would not care to take on, I would get an estimate for repair at a appliance repair store, compared to replacing the unit with a different one.I am sorry to tell you this, but it will only get worse and what I have recommend is for you're safety.
Sincerely,
Shastalaker7
PS Please keep me informed of the situation, as I would love to be of any help you may need.
Dec 05, 2009 | Honeywell HZ-338 Ceramic Compact Heater
Worked for me.
Oct 02, 2008 | Lasko 5132 Ceramic Compact Heater
Jan 21, 2008 | Honeywell HZ-325 KAZ Ceramic Compact...
Heating & Cooling Logo
166 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
