Question about Tivoli Audio Players & Recorders
Tivoli internet radio : cannot switch it on. Only by plugging and unplugging the electric cord. When switched off and plugged in, it makes a low zooming noise. Is it an electric problem?
  • 279 Answers
SOURCE: 802.11g Network Adapter Radio Control Switch
It's not a physical switch, and they really should put more thought into the error messages they write. To "flip" the "switch" you hold down your function key and hit F2 (you'll notice a little symbol on the F2 button - that's the "radio switch"). After that, just right click on your wireless connection and choose repair.
Posted on Aug 29, 2007
SOURCE: Tivoli iPal
send it back! I have had 2 fail this way.
Posted on Feb 28, 2008
SOURCE: Samsung TSL3293HF HDTV - TV in Stale State-No picture or audio
Did you get it fixed..I am having the EXACT same problem with mine..would love to knoe how much you are spending. Should I junk it? I have had it for 5 years. Kim
Posted on Apr 21, 2008
  • 3 Answers
SOURCE: amana ptac
you have the white wire on the wrong terminal put it on the same terminal as the red wire on the capacitor and you should be fine,
Posted on Jan 06, 2009
mowerman1857
  • 389 Answers
SOURCE: 13.5hp Briggs And Stratton snowblower.I tried to
Concerning your starter/pull cord problem, what has probably happened is that due to sitting idle for an extended period, the pinion gear had stuck in the down position on the clutch drive.
When you engaged it with power it spun as it was supposed to do but did not immediately spin up into the ring gear.
After you released the starter button and it began to slow down the gear spun up into the flywheel and jammed because it didn't have enough power to turn the engine.
A usually simple fix for this is to turn the engine backward by hand just enough to relieve the tension and the return spring will push the gear back down.
At this point, you can try the electric starter again and it should work properly. If it does not work, you will have to remove the starter and clean and inspect the starter drive on the top of the starter.
Concerning the fact that it would not start, you more than likely have some old fuel trapped in the bottom of the float bowl.
You may be able to remedy this by spraying some carburetor cleaner in the carb while trying to start it.
If it has spark and everything else is in good condition, it will start and run as long as it has carb cleaner getting to the engine so you may need to spray it a few times while it is running on that and sometimes the stale fuel problem will clear itself.
If it doesn't clear up and run on its own without the carb cleaner after 3 or 4 shots of spray you will need to remove the float bowl and clean it and the main jet with the carb cleaner.
Protect your eyes and bare skin while using the carburetor cleaner, it will injure you. Do not spray it on any rubber gaskets or seals, it will swell and ruin them.
Sorry for the "book" I wrote but I am trying to explore as many possibilities as I can to get you up and snow blowing!
Posted on Nov 05, 2009
Testimonial: "Cured the problem just like you said. Thanks"
Tivoli radio
An internal fuse may have opened or there could have been spontaneous power supply failure.
Dec 08, 2017 | Audio Players & Recorders
I have a Tivoli Music System radio/CD player. When it is moved to another room and plugged in at the new location, it won't run! The screen lights up a little, but has to sit for 30-40 minutes bef
The Tivoli Music System must be left without power for a minute (60 seconds or more) anytime it is unplugged, before being plugged in again. If you observe this little rule when changing rooms, it should turn on and be usable immediately (after ensuring it has been at least a minute since it was last connected to power.)
Nov 18, 2012 | Tivoli Digital AM/FM/CD Hi-Fi Music System...
Bought a used iPal and it only came with a european compatible plug. I bought a US converter. Plugged it in and can't make sense of it. The radio doesn't work. When off, there's no green light....
If the radio has a European-style plug, it's probably expecting 220-volt power since that's their standard. If you got a plug adapter but not a voltage converter, the radio won't work because the line voltage is too low.
Check the radio for a ratings label which will tell you for sure what the radio expects. There may be a selector switch on the back which will let the radio work on our line voltage. Otherwise you'll need to purchase a voltage converter to use the radio.
Jun 20, 2011 | Tivoli (PAL) AM/FM Radio
Radio will not play when turned on unplugged, but will play via battery when plugged in to powerpack,, turned on, then unplugged.
I have the same problem with 2 Pal radio, I'm trying to find a solution, i think the trouble is in the switch to turn it on/off which has a bad electrical contact, I will tell you if I can find a solution. Phil
Apr 17, 2011 | Tivoli (PAL) AM/FM Radio
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
Jul 30, 2010 | Tivoli Henry Kloss Model Two FM/AM Radio
My Tivoli Model One makes a loud screech/buzz noise
I had the same problem and was able to repair it quite easily. Only thing needed is some basic soldering skills.
Problem description:
  • Suddenly a quite loud and disturbing (scratch/screech/buzz) noise appears.
  • Sometimes the noise is gone but it reappears sooner or later.
  • Changing volume or radio band / input (am, fm, aux) does not affect the noise (even on volume turned down all the way).
  • The signal coming out of the Headphones / Rec Out plug is not affected.
Cause:
  • Cold solder joints
Solution:
  • Unplug from mains
  • Remove back panel (the two black screws next to the plugs in the center). The back panel sticks quite firmly, so it might help to remove the front panel first (the 4 screws in the corners) and carefully press out the back panel from the inside. (The other two (silver) screws are used to attach the transformer to the back panel) and need not to be loosened.)
  • On the circuit board at the back panel locate the plug that goes to the speaker (is says "J2"). Check the solder joints. In my case, looking closely, I could see that they're not good anymore.
  • Renew the joints by heating them up and applying some fresh soldering tin. I also renewd the joint from the wire bridge next to the plug. Just check the other solder joints on the board.
In my case afterwards the problem was gone and the device is working properly again.
Apr 03, 2010 | Tivoli Kloss Model One AM/FM Radio
Tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Dec 26, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli iPal
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Battery won't charge
this is what you should do: charge it.. then when it's still connected to the power switch it on.. then you can remove the power plug and enjoy it for hours...
I know it's weird...
Nov 12, 2006 | Tivoli iPAL AM/FM Radio
Open Questions:
83 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
