Question about Haier Washing Machines
Haier hlp23e coin between tub and pulsator I removed the screw from the pulsator, but I can't get the pulsator out. I know there is a coin because I can see it.
    Habit-Forming:
    Scholar:
  • Haier Expert
  • 171 Answers
Get 2 sharp pointed self tapping screws. Screw one into the plastic on each side and use them to pull up with.
Posted on Dec 24, 2016
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: I have coins under my tub in my kenmore elite
DO NOT attempt to turn this washer upside down! The wash tub is suspended by suspension springs and it will dislodge the wash tub from its mounts. The washer also weighs about 200 lbs. Not a bright suggestion.
In addition, if this is an OASIS, no special tools are required to remove the wash tub. It usually involves removing the center cap from the wash plate and loosen the bolt underneath with a socket. You will need to remove the wash tub ring in order to get the wash tub out, however. This is the pastic ring around the top of the wash tub. It simply snaps in place and can be removed by popping the retaining taps free with a screwdriver.
If you hear a rattling noise, I would recommend you check the drain pump first as "titelines" suggested. It is common for items to get lodged in the piump impeller and make noise. Keep in mind...there are TWO pumps on an Oasis. One is a recirc pump. Check them both. If anything has been left in the pump for any significant period of time, it can damage them.
You will need to access them both with the rear panel removed and the wash tilted up so you can access the mounting bolts and screws from underneath. I would STRONGLY recommend you drain all residual water from the wash tub prior to disconnecting any drain hoses. If you own a wet/dry shop vac, this can be accomplished by removing the drain hose from the standpipe and pulling a vacuum on it. This will minimize any mess you may have to clean up later.
If your model number differs from the one you posted this question under, please post back with your correct information. I hope this helps you.
Posted on Nov 30, 2009
localwonder
  • 6784 Answers
SOURCE: haier washer machine HLP23E makes a noise
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Posted on Jan 04, 2010
caroldon
  • 17130 Answers
SOURCE: how to change a pump on haier hlp23e
Check this link: drain valve
Posted on Jun 28, 2012
dgmoore7811
SOURCE: how to remove coin and debri from tub of whirlpool cabrio 6800
Go on utube and search for this issue. It will show you how to disassemble the machine and get to the problem spot. Easy to do just did it last week. Stupid design flaw
Posted on Mar 29, 2014
How do i locate my washer safety lid switch on model haier hlp23e?
slide the tape covered screw driver or plastic spakle knife to pop off the lid, from the two clips in the front. Once that opens pop off the back and under the main washer deliver, you can see the door closed switch.
Sep 23, 2015 | Haier HLP21E Top Load Washer
Haier hlp23e jolting noise spin
You need to level it again. (the knobs on the bottom of it are threaded so you can adjust them to make them level, it can be time consuming, so it is best to start with the one that is shortest.
Mar 23, 2014 | Haier HLP23E Top Load Washer
How to remove coins trapped in a washing machine
firstly removed the pulsater which is found in the tub then see which screw is using unloose it with a srewdriver then removed the pulsater and the coin then replaced the pulsater and screw
Aug 18, 2013 | Sanyo SW-1150T Washing Machine
Change in the waterpump
You can try disassembling the pump only sufficiently to get the coin out but if you go that far you might take a look inside the pump to determine whether anything else is stuck
Feb 18, 2013 | Haier HLP23E Top Load Washer
WATER GOES INTO MY WASHER AND RUNS RIGHT OUT
tub rubber is torn or cracked can be replaced but for cost u might buy a new washer
Nov 18, 2012 | Haier HLP23E Top Load Washer
Haier hlp23e washer makes a rattling sound during spin that almost sounds like coins being slapped by an impeller. How do I fix?
Here's what I did that seemed to fix it. You know that plastic attachment you screwed onto the bottom? I'm pretty sure the noise is made by the bottom of the machine spinning against it. I thought the noise sounded sort of plastic-y, so I removed the bottom and sure enough, there were circular scratch marks on it. I haven't heard that annoying rattling yet.
May 05, 2012 | Haier HLP23E Top Load Washer
Washing Machines Logo
143 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
