Question about Lexmark T642 Laser Printer
Lexmark t630 printer cuts off lanscape layout to left of page, and sends message 'short paper' only when printing from pharmhos software package 'merlin' and only to this printer not other printers networked in the organisation??
  • dumbas Nov 29, 2007
    thanks for sending this, have passed it to it. because not sure of it. Previously lex recognised A4 and printed accordingly,
    this printer has never been set for scripts or repeats only A4 and merlin instructed to print landscape,
    still not running correctly
  • Lexmark Master
  • 1,113 Answers
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Posted on Nov 20, 2007
  • Soulvisitor
    Soulvisitor Nov 30, 2007
    Tell merlin to print in portrait to Lex, does Merlin use Windows driver?
How do you get the Lexmark pro 715 Printer to print on Both sides the manual is not very clear
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Go to the:Layout tab > Print on Both Sides (Duplex) area > Print on both sides
- Click Long edge for print jobs with pages that are bound along the long edge of the page.
- Click Short edge for print jobs with pages that are bound along the short edge of the page.
4 Click the Paper/Finishing tab, and then select a supported paper type.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
Oct 22, 2012 | Lexmark Pro 715 All-in-One Printer
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
May 14, 2010 | Lexmark T630 Laser Printer
I have a lexmark T630 and the fuser needed replacement, now the printer will print just fine with one problem. On every page that prints out there is about 2in from the left side of the paper light print....
Light print is usually caused by a bad charge roll or transfer roll. Can also be caused by a bad HVPS, which I hope is not. But try cleaning the charge roll. Check the transfer roll, it may have shifted all the way to the left. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark T630 Laser Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Only printing 1/4 of page
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
Aug 31, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Lexmark T630 Hangs with Parallel Busy
try replacing the ethernet cards in these printers these have nvram chips that are known to fail. a failing chip can create stalling. t630 632 634 are the only lexmark lasers that will not boot all the way with out the ethernet card
Nov 17, 2008 | Lexmark T630 Laser Printer
Manual feed only
Pull out tray 1 & ensure the gray left-rear paper type clip is completely in the notched hole.
Aug 11, 2008 | Dell M5200n Laser Printer
Lexmark T642 Laser Printer Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
