Question about Home
On a regulator, which side winds the clock, right or left
  • 277 Answers
It depends on the manufacturer.
UsedClockParts.com
Posted on Dec 21, 2016
The clock gains as well as striking on the hour only the once tried setting it right but have had no luck yet what I forgot too mention int a antique clock
needs the mechanism taken out of the casing
and checked
something stripped or broken of its winding part
Jan 30, 2017 | The Watches
I have a Linden mantel clock with chimes and 3 winding squares. Which square is for which function? I cannot seem to find this info anywhere!
I believe the one on the right is for the chimes, the one in the center is for the time and the one on the left is for the gong (on the hour).
Main Page
Nov 01, 2016 | Home
Not sure if first attempt went through so i will try again. We were moving a sligh grandfather clock and the brass weights fell and the weights inside came out which weights go in which brass?
with most old clocks the weights were a means of moving the gears in the clock instead of using a spring
If I am right , to wind up the clock you pulled one lot of weights down and the weights then slowly changed positions from one up to one down
normally the lh weight is the wind up weight and is slightly lighter the than the rh weight
your problem will be determining the correct weight for the rh side as too heavy and the clock will gain time and too light will loose time
Dec 10, 2015 | Watches
How to set radio clock on a 1994 ford ranger
How to set the clock
1.
Turn the radio on.
2.
Press and hold the "CLK" button, press the right (a) side of
the "SEEK" button to increase hours. Press the left (
b) side
of the button to decrease hours. Press the right (
a) side of
the "TUNE" button to increase minutes. Press the left (
b)
side of the button to decrease minutes.
NOTE: The clock displays 12-hour time with no AM/PM
indications
Jun 05, 2012 | Cars & Trucks
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Makes winding in the front end when driving straight or turning right
Hi it needs a hub bearing sounds like the left one
jack up the left side so the left wheel is off the ground and start the vehicle and spin the wheel up to about 30 mph and you should hear the same noise and if not jack up the right side and do the same
hope this helps you
May 11, 2009 | Chevrolet Cavalier Cars & Trucks
Locating the draincock
it is on the back side (towards engine) of the drivers radiator side tank on most GM cars or the left in a few, u must get under the car to see it and turn it. it is black and looks like a clock winding key head.
Apr 09, 2009 | 1994 Chevrolet Caprice Classic
CUCKOO TIME ADJUSTMENT
http://antiqueclock.clockstop.com/CUCKOO.htm
1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
Hope this tip helps.
R/
David
Jan 26, 2009 | Novelty 96512 Cuckoo Phone
Cd player clock settings
Press and hold SEL (select) button on left for 3 seconds
Select CLOCK H on the left or right side of the knob on on the right.
Adjust hour by turning the outside of the select knob
Press SEL to lock hour
Select CLOCK M on the left of right side of the knob on the right
Adjust minute by turning the outside off the SEL knob
Press SEL to lock minutes
Press DISP button
Sep 11, 2008 | JVC Car Audio & Video
Home Logo
56 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
