SOURCE: Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: Over the Counter Goldstar MV1501 1500 watt
You can download the service / repair manual here.
Most computers will open the manual automatically, but you may need the free Adobe Reader.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and reference numbers. Unfortunately it does not give you part numbers for some reason...
You can find & order parts from Encompass here or you can call them toll-free at 866-779-5835.
I would first check the fuse and oven thermostat.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Accessing some components
(especially the oven cavity thermostat) for testing and possible
replacement will require you to remove the oven from the wall and take off the outer cover.
If
so, the installation instructions here are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
Once the fuse and oven thermostat are known good and the microwave functions, if the lights / fan still won't work or won't shut off, then you have a problem with the control board.
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week or so.
At
our Web site, you can get details of our service, plus we have a video
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
The lights can can be
inoperable or stuck on or no bright, too. Sometimes this will similarly
affect the exhaust fan operation or inside light, too.
You should check your light sockets for a short, too.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: I've replaced the fuse three times in my GE over
NO, MW can be LEATHAL.. If a fuse is blowing that means that you have a Phase to Earth fault BAD.
In all
likelihood the mangnetron is failing, or perhaps even the Power Supply is
faulty. You need to have it serviced by a reputable service centre/man.
Ensure
you get a firm "Quote" before proceeding, and remember these days the
cost of repair can equal or exceed the price of a new one.Yes they are right.
