Question about The Home Security
Heath/zenith sh-5105 what I the replacement part number
SOURCE: Heath Zenith #SL-5316 Motion detector light what are settings?
Go to http://www.heath-zenith.com/search.cgi (displays as HEATHCO webpage) and search for SL-5316 ... choose manual below.
See http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Thanks
Posted on Jun 16, 2009
fisherman816
  • 66 Answers
SOURCE: How do I replace the Halogen bulb on the Heath
Unscrew the bulbs counterclockwise with youre finger tips.
Posted on Nov 13, 2009
al_kupchella
  • 843 Answers
SOURCE: Connecting a Heath Zenith Doorbell 172C-A
Do you have a transformer with it? Apparently this doorbell can operate on AC or DC (3-6VDC or 8-16VAC). The usual method is to supply 110 VAC to a transformer with an output of about 16VAC. ------ BE SURE YOU KNOW WHAT YOU ARE DOING WHEN DEALING WITH 110VAC. HAVE A CAPABLE ADULT HELP YOU WITH THIS! ------- Connect one of the two outputs from the transformer to one of the terminals on the bell (this might be labeled COMMON) The other output from the transformer will go to your handheld lead (like in the Operation game). Connect a lead from your patient (as in the Operations game) to a terminal on the bell which is probably labeled for AC.
Posted on Apr 23, 2010
seanpwright
  • 2030 Answers
SOURCE: I'm working on a remodel.
Sorry thats not possible. What you will have to do is get another LE75 and put it in the 2nd location
Posted on Aug 17, 2010
Sebin
  • 712 Answers
SOURCE: I replaced a standard single
So is the problem fixed now? That is what I understand from your post.
Posted on Oct 22, 2010
Where can i find Heath zenith SL-6273 manual or how do i make the product play mp3
Most Heath Zenith product manuals are available here: https://www.heath-zenith.com/support/owners-manuals . Searching for the SL-6273 found two versions of the wireless MP3 door chime. The direct link to the manual for the SL-6273-00 is https://www.heath-zenith.com/system/spree/documents/attachments/000/000/839/original/205371-02A.pdf?1436551434 .
Put the batteries in the door chime. To transfer an MP3 to the door chime, connect it to a computer with a USB cable. Open the folder to view files and drag the new (short, <= 20 seconds long) tune into the folder. Eject the door chime (like any USB hard drive) and remove the USB cable from the door chime.
Next press the Tune button to cycle through the tunes on the door chime for the front door chime. Stop when the desired tune is played. That will be played any time the front chime is pressed. If you add the jumper to pin 8, the door chime will ding as that is the rear rear door sound. For the front door, make sure that the switches (1-7) on the push button match those for the door chime.
I hope this helps.
Jun 02, 2017 | Heath Zenith Home Security
WIRELESS DOOR BELL BUTTON SL-1695-rx
Heath/Zenith SL-6166-C Wireless Plug-In Door Chime Kit ...
www.amazon.com > ... > Door Chimes & Bells > Kits
Amazon.com, Inc.Heath Zenith SL-6198-B Wireless Doorbell Replacement Battery. Total price: ... Plug-in doorbell chime, doorbell button/transmitter with battery, hardware pack ...
Oct 16, 2015 | Home Security
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
Own a Heath zenith sh 5105 motion detector flood light. I wired it to plug into an outlet. Flood light comes on when I plug it in and stays on. Seems as if the sensor isn't working. Do I have it wired...
look to see how you have it wired, most sensor lights have many wires to put together, if it is not wired already from factory, you need to look to see how you have it wired, most sensors have three wires one black one red and one white, black wire goes to power, red wire goes to lamp, white goes to neutral, after all is wired you should have only 3 wires a black a white and a green, black to power white to home neutral and green to ground
Oct 31, 2011 | Home
Own a #182155 secure home SH-5105-WH-B light stays on all the time.testing it in a dark room with door closed,light can be seen under door,never goes out.any help you can offer would be great!
Switch the Dual Timer selector to OFF.
Wait 1.5 minutes for fixture to recalibrate.
Then check fixture again.
http://heath-zenith.hcents.com/data/manuals/598-1152-05.pdf
Aug 04, 2011 | Heath Zenith Secure Home Motion Activated...
Wireing ot lights
Yes, you will need to provide a 120 volt outlet. You should be able to download the manual from:
Jan 20, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Heath Zenith 6150 wireless doorbell
Yes, there is a way to change the security code. See FAQ here:
http://www.heath-zenith.com/servsup_disp_faq.cgi?cat=5
click on "how can I change the security code."
Jan 06, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Home Security Logo
Top The Home Security Experts
vince
 MikeWang
MikeWang
Level 1 Expert
Are you a The Home Security Expert? Answer questions, earn points and help others
