Question about The Watches
I have a regulator, which side winds the clock, i don't want my clock to chime, if I stop winding the chime will it stop
  • 417 Answers
SOURCE: wind up clock has stopped
if you wind it up and it doesn't work your clock need to be oiled the the part can movie and function properly
Posted on Jul 04, 2008
SOURCE: Submariner Winding Slips
crowbar040, you may have a problem with your mainspring click, which is supposed to keep the spring coiled as it winds. What might be happening is it is sticking and coming undone instead of winding. Or you could have a bad gear in your automatic.
Posted on Aug 04, 2008
  • 714 Answers
SOURCE: Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
Posted on Jan 22, 2010
  • 2200 Answers
SOURCE: I have a Regulator "Centurion
By your description the spring is already wound up tight and what happens is that friction is keeping the clock from unwinding and starting of its own accord.
The solution is to manually use your hand to move the pendulum back and forth for a while. It may take a few minutes, but this will force the spring to gradually unwind and kickstarts the mechanism.
Eventually after a few minutes the friction will release, and the clock should begin to work on its own.
To test this after a few minutes - once you have the pendulum started, let it go and it should continue to tick of its own accord.
Thanks for using FixYa. Please do leave a vote for the solution.
Posted on Aug 16, 2010
  • 910 Answers
SOURCE: I just received a Welby
These clock do need oiling every couple of years and should be cleaned at least every 10 years.
One of the winding holes is for the time, one is for the strike and the 3rd is for the chime. These do vary in location from clock to clock so I can't advise any further. It sounds like this clock has 2 differenct chimes depicted by the SIE & EIV7.
I think your best option is to take it to a clock shop and get it cleaned. They should then be able to give you more information on the chimes and its operation.
Posted on May 30, 2011
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
I have an early 1900 clock that I have to wind. I have noticed my clock stops frequently. I go to wind it and it is tight to wind so instead of over winding I tip the clock to start the ticking and the...
You can not unwind the clock yourself, because this requires proper clock makers tools and skills as well. Clock is stopping because it has not been serviced for a long time and the oil in clock has collected dust particles and getting sticky. This does not let the spring unwind freely and is a problem for all cogs and moving parts. Find your nearest clock repair shgop and ask for cleaning, oiling and adjusting. BE AWARE: If you are gonna try to unwind it yourself, you will damage the clock's movement, but most important - you can even brake or loose your fingers, as the clock spring is under unbelievable tension and once released, it uncoils lightning fast and is sharp as a razor.
Oct 28, 2010 | Seth Thomas Watches
Why is there two places to wind a Seth Thomas Corsair E537-000 clock? Any description on the proper tension for winding?
Two winding arbours are in clocks with chiming, because there are two separategears in one clock and each one is driven by separate mainspring. Description for winding is: Wind each spring as long as you do not feel significant resistance. As soon as you feel the winding goes too hard - stop winding.
Rate me, please.
Aug 05, 2010 | Seth Thomas Watches
I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
Hope this tip guides you to a solution for your clock.
r/ David
Apr 06, 2010 | Watches
Don't know how to properly wind Elgin 400 day anniversary clock
Wind the clock until there is a sudden increase in resistance (it is then fully wound). So not apply a great force, as older clocks may be weaker and overloading the spring may break the termination and result in a new spring being required.
If you think it is becoming too stiff, just stop winding and see how long it runs for. I have often heard the term "over winding at clock" but have never quite understood the term. As a retired engineer I think that springs that break because of overenthusiastic winding are probably near the end of their life anyway.
Jan 13, 2010 | Watches
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
May 02, 2009 | Watches
Wind up clock has stopped
Jul 04, 2008 | Watches
Watches Logo
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
