Question about Sansui Televison & Video
SANSUI 5.2 CHANNEL COMPONENT SYSTEM HT4007 EX
    Top Expert:
  • Sansui Master
  • 74,459 Answers
What is the problem with it?
https://electronicshelponline.blogspot.com/
Posted on Dec 19, 2016
Sansui model LCD47HWB (no remote!). Turns on (green light) and the screen goes a shade lighter. Nothing comes up on screen even when i press volumn, channel or source there is no information at all.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 09, 2016 | Sansui Televison & Video
Where to find the owners manual for the Sansui QRX 7500A?
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Dec 19, 2015 | Audio Players & Recorders
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Will not hold channel memory after tv turned off and then turned back on - have to go through channel memory step each time
Sounds like a main system control memory IC fault. Contact any service technician, or the authorized service center for Sansui.
Gopakumar Gopalan Google
Mar 13, 2014 | Sansui HDLCD3250 32 in. LCD TV
Sansui lcd tv will not search for channels it goes to the search screen for about 5 sec then goes back to channel 2
Try it after a hard reset. If it do not help you, check and replace its main system control memory IC.
Mar 05, 2013 | Insignia IS 20" TV040919 TV
Sansui SV-2110K, Channel lock
Click here and try to download the user manual to your Sansui TV, and refer it how to make a factory reset to your tV. If it do not help you, the main system memory IC might be faulty, and should be replaced.
May 14, 2012 | Sansui Televison & Video
I have just reinstalled my Sansui component stereo system, and have a couple of problems. One is a scratchy noise on one speaker channel. The other is a seeming lack of results when I attempt to use the...
Buy some electronic contact cleaner, remove top, spray volume and balance pods and use the straw provided to target the small hole. Move controls back and forth as you apply the cleaner. If that fails! then the problem is a bad driver or audio output semiconductor.
Mar 16, 2012 | Audio Players & Recorders
Sansui TVM1300 13 inch TV - Set Auto Channel does not work. I go into the Menu and start Auto Channel and it does not find any channels. Yet I can manually enter the channel number and it will go to that...
Sounds like AFT, AGC voltages are not proper. Contact any service technician. The main board of your TV has to be troubleshooted.
If the main system control memory IC is bad, this kind of fault can occur. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
May 19, 2017 | SansuiS3275 TV
CODE RETRIVAL FOR A SANSUI TV MODEL
I lost the remote to my Sansui TV and can't remember the model number. can I get a remote to replace it?, the tv was bought in 2004
Nov 19, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
