Question about Humidifiers
I have an Air Innovation Clean Mist Smart Humidifier that is almost three years old. I packed it up for the summer but now it won't come on. I've followed the directions and the outlet works.
Model MH602
  • 482 Answers
SOURCE: mold in vicks cool mist vaporizer
if you can take it out side and plug it in, put some bleach in it and let it run for a few minutes. then wash it out and run the rest of it out.
Posted on Dec 16, 2007
  • 7 Answers
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
SOURCE: Cool Mist Humidifier Filter Drying Out
Do you have tried to use without filter?
Posted on Jul 17, 2008
SOURCE: cleaning
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
  1. Turn the switch to off and unplug the corn from the wall.
  2. Remove Water Tank and empty any remaining water from the water tank.
  3. Remove Medicine Cup from the Cooling chamber from the Base. Carefully remove the Cooling Chamber and Removable Water Tray from the Base.
  4. Soak the Removable Water Tray in a solution of white vinegar and water for 20 minutes. Rinse thoroughly and then wipe dry with a soft clean cloth.
  5. Fill the heating chamber with undiluted white vinegar. Let stand for 20 minutes. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Heating chamber to remove scale. DO NOT use soap, detergents or abrasive cleaners.
  6. Rinse the Heating Chamber using clean warm water, being careful not to submerge the base in water.
  7. The Water Tray, medicine Cup, and Cooling Chamber are top shelf dishwasher safe.
Posted on Jan 18, 2009
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Germ guardian h3000 not blowing air
I have a Vicks, similar, and it recomends a little table salt in the water to create a mist, read your manual and see if this helps. Don't go overboard on the salt, or you'll have old faithful instead of a mist!
Apr 07, 2013 | Germ Guardian H3000 Humidifier
Runs for a few minutes then stops
Forget the visually appealing white mist humidifiers that leave you with a white slime to clean up. Get yourself a warm mist humidifier without the hassle, works better and no mess to clean up!
Jan 22, 2013 | Air-O-Swiss 7133 Humidifier
How can you tell if it is working or not, it used to have a visible mist coming out, now it doesn't, you can feel air coming out and hear the fan working, but is it working?
Check the fan area on the base. My spongebob humidifier did the same thing, and then I noticed smoke and sparks coming from the fan area. i am trying to contact Crane for a replacement, but its 2 years old, and warranty is over.
Oct 25, 2010 | Crane Cow Humidifier
Do I add salt with the water when using this cool mist humidifier
Ive been down this road before,sorry your son is sick.
Take a teaspoon of salt and add it to a full tank,it will break up the corrosion on the heating elements,a teasspoon of baking soda will help also.
This will not hurt anyone if it blows into the air with the steam.
May 12, 2010 | Vicks Healthmist 4100 Humidifier
I have a brand new hm500 humidifier and when I turn it on I can see the mist being produced in the reservoir but it won?t come out the top. How do I correct this?
If you can see the mist, then, it is working. The outlet
port of your humidifier could be closed/stucked up/clogged. Please check this the outlet port.
Jan 06, 2010 | Holmes Products HM500-UC 1 Gallon...
I'd like to clean my sunbeam warm mist humidifier
if you mean by stone build up, you need a de scaler such as clr from any hardware store. let it soak on the crusty parts overnight the rinse well with water. toothbrush helps too.
Nov 25, 2009 | Sunbeam Health at Home Warm Mist...
Replacement filter question
Filter part number is BCM100. Filters are sold at Sears. Also available online. Part number is listed on bottom of humidifier.
Dec 04, 2008 | Bionaire BCM7204-U 3 Gallon Humidifier
Mold in vicks cool mist vaporizer
Dec 16, 2007 | Vicks V5100N Humidifier
Humidifiers Logo
Top Humidifiers Experts
Paul Carew
Are you a Humidifier Expert? Answer questions, earn points and help others
