Question about Home
I need a bowl with the chains - Home
Drive belts and driving sprocket
Patent US4832502 - Agitation supporting and ... - Google
GoogleMeans for supporting and driving agitators in commercial food mixers and the like ...Agitator means according to claim 1, wherein said drive belt has a tapered cross .... 1, 2 and 4) which is coupled to a bowl-tilt shaft 42 by a drive chain 44 and ...
Patent US4832502 - Agitation supporting and ... - Google GoogleMay 23, 1989 - Agitation supporting and driving means for commercial food mixersand the like ... said agitator driving shaft, and wherein said drive belt extends between.... of the drive chain in the area adjacent the mixing bowl and agitators,
Robotic Mechanisms - PULLEYS and BELTS 51045 ...
Jul 17, 2013 - A large drive pulley driving a smaller driven pulley by means of a belt or.... bikes, agricultural machinery, food mixers, washing machines, lawn mowers, etc. ...Chain Drive System: A system consisting of a chain and sprockets ...
Feb 03, 2016 | Food Mixers
What to do if your toilet stops working
When a toilet stops working it can be a major inconvenience. If your toilet isn't working right, try the simple fixes below.
If the toilet doesn't flush:
When you jiggle the handle, nothing happens. Remove the lid from the toilet tank and peek inside. Most likely, either the chain came off at the lift rod or flapper end, or the rod broke in half. If the chain came off the rod, you can simply reattach it. (Finding the right amount of slack will take some trial and error.) Likewise, if it came off of the flapper, it can easily be reattached.
If the lift rod (the arm attached to the handle) is broken, you can purchase a new rod and handle assembly for a few bucks at just about any hardware store. A plastic nut holds the handle into the side of the tank and the whole assembly can be popped out and replaced. Once you've installed the new assembly, reattach the chain.
If the toilet keeps running:
Remove the tank lid and watch the toilet as it flushes. You'll probably see that the chain is too tight, causing the flapper to not close all the way, which results in water continuing to drain out and having to be replenished. Loosen the chain a little and see if it fixes the problem.
Another cause of a constantly-running toilet is an improper float height. The float is the balloon-looking thing that sits on the end of a shaft and falls and then rises when the toilet is flushed. When the float reaches a certain height, the fill valve is closed and the water stops flowing. If your toilet is running longer than it should, push down a tiny bit on the float and see if it stops running. If it does, the float just needs to be adjusted downward a little (by turning the screw at the other end of its shaft). You may need to try a few different heights to determine the optimal position of the float; adjust it slightly and flush the toilet, then adjust it again if necessary.
If there's not enough water pressure:
The chain may be too loose if there isn't enough pressure. With the tank lid off, watch the toilet flush. If there is too much slack in the chain, the flapper may close prematurely, reducing water pressure. Tighten the chain and see if that makes a difference.
Loss of water pressure can also be caused by the holes in the toilet bowl getting clogged up. There are little holes all around the side of the bowl, where water is forced into the bowl to refill it after a flush. If any of these holes get clogged, clean them out with a round file, a nail punch, or a similarly-shaped instrument. (Don't push too hard or hammer on the bowl.)
If the toilet overflows:
If your toilet overflows, the first thing to do is to turn off the water to the toilet. There is a valve on one side of the toilet, where the pipe runs from the wall to the toilet. Turn this valve clockwise to close it.
Once the water is off, use a plunger to try to clear the clog. If it works, you'll see the water drain out of the bowl. If the plunger can't clear it, try a simple drain-cleaning tool like a Zip-It or Turbo Snake. If you don't have anything that can remove the clog, or if the clog remains even after trying to clear it, you'll need to call a plumber (or buy yourself a closet auger or plumber's snake).
If you are able to remove the clog, turn the water back on and flush the toilet to make sure the clog is completely gone.
on Feb 06, 2011 | Plumbing
Keeps on pumping out water from the bowl even when there is no water in the bowl
follow this steps and fix it.
Adjust or replace a flush handle:
  1. Remove the cover from the toilet tank (the higher part at the back of the toilet). If the handle is loose, tighten the locknut with a wrench. If the nut won't budge, apply penetrating oil and let it set before removing.
  2. Unhook the chain from the trip lever and slide the trip lever, with the handle attached, through the hole in the tank.
  3. Soak the handle threads in vinegar for an hour or so to remove mineral deposits, then scrub clean with an old toothbrush.
  4. Reinstall the assembly, tighten the locknut and adjust the lift chain (see below).
Adjust the lift chain:
  1. If the handle must be held down while the toilet is flushing, the chain may be too long. Shorten it by hooking the upper end through a different trip lever, or use long-nose pliers to open and remove some chain links. Alternately, replace the chain with a new one.
  2. Some flush assemblies have a lift wire instead of a chain. If the wire binds against its guide, flushing is impaired. Loosen the guide with a screwdriver, then adjust it so that the flush valve falls freely onto its seat.
Nov 24, 2013 | Home
How to change the flapper in a toilet bowl
flapper is a rubber device that blocks and releases water and is conrolled by chain attached to the handle. Make sure you have correct new flapper. The old one removes easily. Unattach chain. REconnect new flapper, the chain and test flush.
Jul 27, 2013 | Home
About every 20 minutes or so, more water is released into the bowl from the tank. Toilet is less than 1 yr old ,model 4021
The flapper that stops water from entering the bowl after flushing needs adjustment. The chain is probably to short.
Aug 20, 2011 | American Standard 4021 White Cadet 3...
Charlesnapostolou@yahoo.comI went to flush my Toto toilet and it would not flush. I took the cover off and discovered that the chain was still attached to the horizontal bar but nothing else. To what do...
There is a piece thats actually called the flapper. It is a rubber flap that has a hing on it and is attached to the bottom of the tank. When you flush, the chain pulls this flap up and allows the water to go out of the tank into the bowl. Attach the chain to the unhinged side of this flapper. Hope this helped.
Mar 01, 2011 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
The water leak to the bowl. How to fix? Thanks.
This usually indicates one of two things: (1) a poorly seated flush valve ball, which can be easily adjustedor replaced, or (2) a flush handle chain that is too long and is getting caught between the flush valve ball and the seat, which is easily remedied by shortening the chain between the flush handle and the flush ball.
One other possibilty is that the fill valve is not shutting off the bowl wash function. There is a small adjustment screw for regulating the flow.
Dec 11, 2010 | Home
The flow of water into the bowl does not stop after the toilet is flushed.
Nov 23, 2010 | Eljer Home
Home Logo
51 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
