Question about Aprilaire Humidifiers
Where to connect 2 wires from Aprilaire 760 to Lennox EL296uvh control board
I have a recently installed Lennox EL296UHV furnace and an Aprilaire 760 with a manual humidistat. During the annual inspection, the technician said that the 760 needed a new control board and disconnected the unit two bare red and white wires from the furnace control board before I could see where it was wired in. They wanted to replace the unit with a new one at a cost of several hundred but I opted to buy and install the board myself having replaced such things before. I just want to make sure to connect the wires to the correct locations on the board.
  • 147 Answers
SOURCE: Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Posted on Nov 17, 2008
  • 290 Answers
SOURCE: he 260a wiring w/humidistat
try this forum...there are wiring diagrams posted there:
Posted on Dec 12, 2008
  • 88 Answers
SOURCE: HE220A direct wiring to protech 62-24084 control board
it is best to use a seperate transformer for the hummidifier, but in some cases you can use the low voltage t-stat wire that runs your furnace, you will need to have one wire run to common, and the other to the heating side of your low voltage, normally its the red wire hooked to the w circuit of your terminal board, if you do decide to go with an extra transformer, make sure you you have it wired to bring on the humidifier only when the unit calls for heat, hope that helps
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: Aprilaire 560 does not work. No clicks
I just solved a problem with mine today.  One of my low voltage power wires to the humidity control had a bad connection.  I reconnected it and I could again hear the solenoid valve clicking as I adjusted the dial control.
I found the problem with a voltmeter:  there was voltage at the power terminals on the humidity control terminal board, but there was no voltage at the solenoid valve terminals.  It was hard to push my big wires into the terminal board, but I finally secured the connection!
Posted on Jan 28, 2009
  • 8 Answers
SOURCE: Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Posted on Feb 04, 2009
Aprilaire 760 keeps running
Is this a newly installed unit it sounds as if there's a wiring issue. Could you show a picture of the wiring terminals. If this is not a new install try turning of your furnace fan.
Nov 02, 2014 | Aprilaire 700 Humidifier
Have a aprilair 550 for some time. Installed a new Lennox G61MP furnace and the technitions failed to reconnect the wiring that powers the humidifier. Need wiring schematic. Does humidifier transformer get...
Hello, yes the transformer will get a 120 volts from the Furnaces control board, there should be a terminal labeled HUM on the control board. You need to bring 2 wires one from HUM and one from a nuetral tap on the board to the line side of the transformer, this way every time the blower motor on the Furnace turns on the humidifier will aswell.
Aug 23, 2011 | Aprilaire 550 Humidifier
I have an aprilaire 550 that is not working. I found 2 wires coming from the humidity control, one goes to the solinoid, the other is hanging in mid-air. Where is this second wire supposed to be...
Hello, it depends on what type of setup you have with your humidifier. If you have a current sensing relay or sail switch than that wire connects there, howevere, if you have the humidifier that is powered by a furnace control board than that wire will connect to the transformer that the control board is providing with 120 volts with.
Dec 27, 2010 | Aprilaire 550 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
Water runs when furnace is off, but stops when furnace is on.
the 760 humidifier does not need a transformer wired externally. the 760 has its' own 24v transformer inside the fan compartment. this transformer will provide the power to enrgize the water solenoid as needed. it sounds like to me the additional trasnformer is hot all the time. when the furnace comes on, the unit gets power and the internal transformer is cancelling the power from the external transformer. this would explain why it quits running when the heat is on. since the external transformer is hot all time, when the heat shuts off, the solenoid is getting energized by the external transformer. to make this run correctly, you need to get rid of the external transformer. leave the humidifier high voltage wires hooked up so they are only hot when the furnace runs. if you have a humidistat that has a r and c terminal, you will need to wire these directly to the r and c on the furnace control board and move the switch inside the humidistat to "power". make sure it is not on "bypass". then wire your 2 brown wires from the humidifier to each of the "h" terminals on the humidistat. if you have a humidistat that only has 2 terminals, wire one brown wire to each of the terminals. this should allow it to run properly.
Jan 28, 2009 | Aprilaire 700 Humidifier
Aprilaire 760 humidifier. no power to humidastat
the 760 send power out the humidistat is just a switch if you touch the two brown wire coming outof the 760 the humidifier should come on if it doesnt and you had appiled power to those wire you probably shorted the 760 control board
Jan 15, 2009 | Aprilaire Humidifiers
AprilAire 760 not running after installing new circuit board
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Nov 27, 2008 | Aprilaire 700 Humidifier
Aprilaire 550 doesn't seem to be getting power
See if you have a screw marked EAC This to power an Electronic Air Cleaner unlike the HUM it also gets 120VAC only when the fan comes on. Not sure what make of furnace you have but if your heat is working OK don'tn change the control board the can be very expensive. there are other ways to wire humidifiers without using the HUN screw
Dec 23, 2007 | Aprilaire 550 Humidifier
Humidifiers Logo
49 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
