Question about Platinum Televison & Video
  • 70 Answers
SOURCE: Remote Control
have you tried leaving the batteries out for an hour?
Posted on Jul 28, 2008
SOURCE: decimal places
How many decimal places are in the answer of this problem? 3.7844236 times 456.93874513
Posted on Nov 10, 2008
  • 268 Answers
SOURCE: I have Print Master Platinum 15- 5 CDs only - no paperwork
The install is pretty straight forward. Just start with disc one or disc labeled install cd (or similar) The manual is just guidance and not needed unless you prefer to reference to it. If you do need it you can visit the support section of the Print Master website to download a new copy.
Thanks Live-Tech 1-888-361-8511
Posted on Jan 29, 2010
  • 60 Answers
SOURCE: remote was reset to set
Press and hold both OK and 1 buttons on remote for 5 seconds.
If it doesn't work, repeat again.
Posted on Apr 08, 2011
  • 12223 Answers
SOURCE: sportcraft platinum volleyball set 1-1-23-872 FP manual needed
Dear Sir:
Please go to the next webs:
God bless you. sincerely.
Ernesto Cuadra
managua, nicaragua. c.a.
Posted on Feb 14, 2012
DSTV Beyond Platinum model B4 remote not working
it is stuck on 2nd tv which i do not have, how can i return to one tv only
thank you
Oct 22, 2013 | Televison & Video
My decoder - dsd 1131 does not respond to his remote control.Ive checked the batteries..they are ok.
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Nov 28, 2010 | Televison & Video
The dvd mode was changed do 2 how can i change it back to mode3 the remote does no work
I have a dvd SONY RDR-GX220 Recorder from the year 2006 and i want to connect this DVD to Videorecorder and decoder for TV, beucause I want to see TV connect with decoder; Videorecorder and recorder and play DVD. After change (from SYSTEM MENU and submenu Other from DVD3 in DVD1, I mistake beucause i know to not must change), remote control NOT ANSWER at the DVD. I can possibility General RESET manually this DVD and i can this function the remote control before changed?or in the remomote control?
Oct 28, 2010 | Sony RDR-GX220 DVD Recorder
What is petrol mix and how do i start it,I would also like a manual or some information on the above model.
Your question does not include a manufacturer or model number; to provide all you ask we need them (below).
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Start Procedure
1. Ignition on/off to on.
2. Set compression release – optional step even if saw is equipped with a compression release.
3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
4. Set compression release – optional step even if saw is equipped with a compression release.
5. Push (open) choke pull starter until it starts. (usually first pull).
3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Thank You for using FixYa.
Jul 19, 2010 | Garden
I have a symphonic tv i need tha code to make my all for one remote work for it i use to have it but threw it out by mistake i dont want to have to throw the remote away
To control your Symphonic TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0180 or 0171
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Nov 18, 2009 | One For All URC-3021 Remote Control
Remote is stuck in dvd 3 mode
  1. On your remote, push and hold "Enter"
  2. At the same time, push and hold "2"
  3. Keep them down for about 5 seconds
  4. Your remote should now work with the unit
  5. You can go to the set up menu and change the unit back to DVD3 if you wish, but you'll then need to repeat these steps using the "Enter" and "3" buttons
Oct 08, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Televison & Video Logo
20 people viewed this question
Top Platinum Televison & Video Experts
ray gallant
Tom Chichester
Are you a Platinum Televison and Video Expert? Answer questions, earn points and help others
