Question about DeLonghi Coffee Makers & Espresso Machines
New DeLonghi ECAM23.260 beeps at every surge of espresso into cup.
Brand new, I know it shouldn't do this since we've had another DeLonghi for 10 yrs and it never did that beep while pumping espresso into cup. Very annoying and we will return if there isn't a fix. Get our old DeLonghi repaired again and move on. Any idea what that is or what to do??
  • 4 Answers
SOURCE: DeLonghi EC701 Pump out
I had the same issue. Scale build up in the port that routes water to the boiler outlet for the coffee filter basket. Frother tube was fine.
I used CLR to open it back up. Used 1 part to 4 of water and ran a whole reserviour through the unit. At first, it only dripped and then finally it blew open when the CLR dissolved the scale.
Make sure to run lots of clean water through the unit after so that you don't end up drinking acid with your next cup. I ran about a gallon through to rinse it out.
Posted on Mar 26, 2008
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
SOURCE: Leakage when filling espresso cup
I had the same problem, there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round. Replacing it with a seal from the hardware store corrected my problem...GOOD LUCK!
Posted on May 31, 2008
  • 464 Answers
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Posted on Nov 08, 2009
SOURCE: Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Posted on Mar 23, 2010
How do i clean inside the 12 cup elect percolater? It hasn't been cleaned or used in yrs. still works
Hi. Just use a half of a cup of bleach. let it siy for 10 minutes then shake it up. It should look like new.
Sep 30, 2014 | Faberware 12-55 Cup Coffee Urn
Coffee not hot enough
Ive had this machine for over 3 yrs now and agree the coffee could certainly be hotter. I usually blast hot stream from the milk jug by pressing the clean button for 5-10 secs. This does help. Also by having the cups heated up on top of the machine also helps. But i usually always give the completed coffee a 10 second blast in the microwave to get it to the temp i like. Its not ideal i know, but there seems no other way. Oh and make sure the temp is on high in the menu.
Dec 11, 2012 | DeLonghi ESAM6600 Espresso Machine
Brand new machine and the pressure gauge doesn't appear to be working, I've made about 10 coffees over the weekend and experimented with the tamping etc. And the gauge has not moved once? Am I...
It could be a faulty machine, what is your grind setting? Make sure your using the dual wall single cup as a test. Set the grind to around 13 and grind your own beans, don't use supermarket bought beans or preground coffee. Both are garbage.
Also if your using the dual wall basket, make sure that you leave the dial guage in the dual wall setting. Then tamp the coffee so it sits roughly 3-5mm below the rim, this is what I have found is best for this unit.
Then secure group head in to unit, press single cup and you should hopefully get a pressure reading, if it isn't going up you are under extracting and your grind is prob to coarse (correct me if I'm wrong), I've found 13 is not to coarse not to fine. Shouldn't feel like fine sand, when coarse but not powdery.
If the gauge does not move in to the grey area your unit is most likely faulty.
Jun 05, 2011 | Breville Fresca BES860 2Cup Coffee Maker
How much coffee to add for 20, 40, 60 cups of coffee in the 60 cup DeLonghi coffee urn?
I like my coffee pretty strong and I use 2/3 cup coffee to 10 cups of water...
You may be able to use 1/2 cup to 10 cups if you don't want it too strong...
You must experiment a bit as different coffees will vary also...
Apr 30, 2011 | DeLonghi BAR 140 Espresso Machine
Boought brand new delonghi magnifica 3300 and did everything the directions say, it turns on, and the motor runs, but no water comes out when we try to run the water for the first time out into the cup...
Read instruction manual first before assuming there is problem. It happen we are not familiar to the operation of the machine the troubles becomes- "operators errors rather than machine errors".
If you already read operating manual and still not yet understand. Call their service hotline, ask something about your problem.
It easy as that! I hope my advice help you.
Apr 04, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Oct 23, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
No water light on new delonghi magnifica
I had the same problem.
As the machine is brand new, try washing the infuser under the hot water tap and then dry it. I then made a 2 cup long coffee and the red no water light stayed off.
Mar 24, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
