Question about Cell Phones
I dont know how to press menu off on resolutin reminder without pressin a number like 2
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
Mar 11, 2016 | Televison & Video
Ok my power button is missing like i can see the motherboard, I wanna know if theres a way to tuern it on by pressing on certaint spots on the board. pleas dont wanna hear its bad or could hurt you. I just...
Without seeing your PC I'll have to give you two options.
1) Assume you are just missing the plastic panel button on/off cover -
Should now be exposed a circuit board with a tiny on/off button. Pressin that will work. But a) Its delicate b) Your goin into exposed circuitry; shocking.
2) You are missing the on-off circuit board also. Will need disassemble and replacing
Both parts are reasonably cheap and are worth replacing. See Ebay
Aug 10, 2012 | Toshiba Satellite A205-S5804 Notebook
Solving linear equations in 3 variables by matrix method in casio fx-115ES
Press key Mode, first select option 5:EQN (by pressing key 5), then option 2: a_nX+b_nY+c_nZ=d_n (by pressin 2).
Now input coefficients from equations in table (each column is for one variable), just type in number and press =, then use arrows to move to another cell.
Sep 02, 2011 | Casio FX-115ES Scientific Calculator
Cant get to install window after format.... keep on boot my cd without asking me to press any key... how to install window?
hi, in order for you to boot to your cd, you have to keep on tapping F12 after you restart it, you'll get on to the boot menu, once your on the boot menu choose ODD CD or DVD and then keep on pressin enter until it boots from the cd. hope this helps goodluck!!!
Jun 12, 2010 | Gigabyte GA-K8NE (04719331711023)...
Screen resolution reminder.
go to the control panel double click DISPLAY then select setting then select 1440x900
Jan 09, 2009 | E-Machines eMachines Desktop PC
New codes required
go to menu then type in 1570 ok on nagravision then select what network ie telepest then type in 00 numbers press ok to store then change 00 to 01 by pressin arrow key right next to ok button then type in 01 numbers press ok then exit out.
Chris (ziraffa)
Dec 31, 2008 | StarTech.com StarView SV211K 2-port KVM...
How do you enter the codes into the starview 2 box
go to menu then type in 1570 ok on nag then select what network ie telepest then type in 00 numbers press ok to store then change 00 to 01 by pressin arrow key right next to ok button then type in 01 numbers press ok then exit out.
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Dont know how to change dvd with out useing skip botton
Press the Display button located in the middle right of the remote. This brings up a menu on the tv that shows the dvd number. Press the right arrow button to get to the number. You can then enter the number of the dvd you want. After you have entered the number press the enter button. This will cause the desired dvd to load. You press the Display button again to tun off the menu.
Nov 22, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Our competer crashed AND WINDOWS WAS TOTALLY UNABLE TO EVEN OPEN. wE BOUGHT OUR COMPUTER 2-3 YEARS AGO USED AND DONT HAve the original windows xp disk or registration numbers. Are we just out of luck on...
hi,
reboot the pc and press F8 for the boot menu,
select Last known good configuration.
else again come to boot menu and select safe mode. if it boots up to safe mode, let me know.
Jul 01, 2008 | Computers & Internet
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
