Question about DCS Kitchen Ranges
I have a DCS Range Model # RGT-364GL. the user guide said it would take 30-90 seconds to ignite, it took 5 minute, now it takes about an hour, what would be causing this.
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
  • 126 Answers
SOURCE: preheat issue with a new kenmore electric range
some of the newer ranges only pre-heat using one element. this gives them a better energy saving rating
Posted on Nov 23, 2007
  • 833 Answers
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Posted on Dec 13, 2007
  • 97 Answers
SOURCE: Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
Posted on Jul 11, 2009
SOURCE: DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Posted on Sep 09, 2009
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
Took my dcs outddoor grill apart to clean. is there a diagram as to how to put it back together correctly?
The user manual for the DCS grills seem to have very good pictures and an installation guide that ought to give you a good idea of what goes where. The guides are available as .pdf files.
http://www.dcsappliances.com/customer-care/user-guides/index.cfm
If you'd rather speak with a customer service agent, there's a toll-free 24/7 number: 1-888-936-7872
Be sure to have your model number handy, and you should be well on your way to having your grill back in order.
Feb 27, 2011 | DCS Kitchen Ranges
Oven will not keep temp and making gas noise
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 04, 2010 | DCS RGT-305 Gas Kitchen Range
Range works, oven doesn't
We have a very similar problem: "Ready" light comes on immediately when turning on oven/broiler but oven does not heat up.
Mar 16, 2010 | DCS RGT-305 Gas Kitchen Range
Electric igniter does not stop sparking after the burner turns on. how do we troubleshoot?
On my DSC RGT-305 range it wasn't either the spark module or the wiring, it was one of the little rotary switches that sit behind the burner control knobs. It shorted out (verified with an ohm meter). The switch is made by State Tool & Mfg. Co. and the part number is 25300. Wayne
Sep 28, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Oven cavity not working
it sounds like the fir ehas blocked the burner and the injector it needs checking out a god local gas fitter should be able to fix this
Sep 08, 2009 | DCS RGT-364GL Gas Range
Clicking ignitors
Take a hair dryer and dry the spark switches located on the end of each gas valve.
Sometimes when cleaning they get wet and do the clicking thing.
If that does not correct the problem you will have to replace the bad switch.
Mar 19, 2009 | DCS RGT-305 Gas Kitchen Range
Kitchen Ranges Logo
47 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
