Question about Garden
Looking for a gas shut off valve for a Mastercraft 8/26 snowblower.
  • 575 Answers
Just follow the tube under the gas tank. there should be a small valve on the tube itself.
Posted on Dec 18, 2016
Testimonial: "Maybe I should have been more explicit. I know where it is - and it's leaking. I'm trying to find out, where I can get a new one. I'm in Oshawa, Ont."
Mastercraft Snowblower 8hp28inch cut.Snowblower starts to miss and run rough after it is warmed up what is the problem
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=manual+for+a+Mastercraft+8+Hp+snowblower
Feb 05, 2016 | Garden
How do I start my Mastercraft snowblower
check gas and oil
check blower housing (round part) for ice and snow ( clear if needed)
put gas and choke on full
prime 3 times pull cord or hit electric start
repeat if it doesnt start with priming 3 more times
Jan 03, 2015 | Garden
My mastercraft "deluxe" 8 hp, 26" snowblower won't
Could be dirt in the carb. If this engine has a fuel cup on the bottom of the carb take it off and clean it out and clean the fuel jet. It is the little screw that has a little hole through it. If this has any dirt in it the engine will not run. A lot of engines I get in this is a quick fix as most people do not run the old fuel out before they store it for the summer. Check the spark plug as well and see if there is wet gas after trying to start. Maybe your choke is not working.
Oct 26, 2017 | Garden
I am looking for the user manual of my snowblower Mastercraft 22' 4HP
contact sears,is it made by sears? or go to mastercraft.com.
Aug 29, 2010 | Garden
Mastercraft compressor - one pancake type tank ... need pressure
You do not need to use factory replacement switch. Mos t universal pressure switches are set to shut off at 120-130 psi. You will need to check the placement of the unloader valve (1/4 line from check valve) and the quantity of ports as some switches have only one port and others have 3-4. Check ebay for good match and low price. Good Luck
Aug 01, 2010 | Air Tools & Compressors
I need a manual for a Mastercraft 8 Hp snowblower P/N 316 582 515
Jim
Dec 03, 2009 | Garden
Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Dec 18, 2008 | Mastercraft Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
