Question about GE Washing Machines
Ge pgp989sn2ss knob not turning - GE Washing Machines
  • Satyendra Srivastava
    Satyendra Srivastava Dec 18, 2016
    This question is about ge downdraft cooktop. Knob is good. I can push it down but not turning counter clockwise. Other 3 knobs are working but this one not turning.. it seems like the assembly where knob fits is stuck.
  • 575 Answers
If the knob does not go down all the way, it wont turn. Try removing the knob and adding a tiny ball of aluminum foil inside the knob (this will allow you to push the knob a little bit further down). Good luck!
Posted on Dec 18, 2016
What can cause an electric GE dryer to not start? Model number DCVH680EJ1WW. cogtinuity with motor switch, door switch, high limit fuse, thermistor & no cogn. with the thermodisc or heating element.
As a repair technician, just came across this crazy situation with GE / Hot Point / Moffat machines several times. It is all made by GE corporation.
The Dryer is not starting because your cycle selector knob is broken inside and it is just turning without turning the timer selector.
GE corporation machines are good. But those damn chinese plastic knobs break from inside. I have driven 50 km to find out the knob is broken. I had to charge the poor customer.
Apr 15, 2015 | GE Dryers
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
Ge washer knob just spins to turn on
Try pushing the knob in then it might turn. At least thats how my GE works.Pull it out for off,in for on.
I hope this helps.
Nov 05, 2009 | GE WBSR3140DW Top Load Washer
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
Aug 19, 2009 | GE Cooktops
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
