Question about GE Refrigerators
Water in reservoir might be frozen - GE Refrigerators
I spent an hour looking at many of the suggestions posted here and at other sites. I tried the easiest first and it worked so I am sharing it on all the sites that were helpful. Turn down the temperature of both the freezer and the refrigerator. I then tried holding the door switch closed and repeatedly pressing the lever to dispense water. After a few minutes I walked away for 30 minutes leaving door closed. WHen I returned the water flowed perfectly. good luck
Posted on Sep 18, 2010
Water wil not despense
Could be a few things. Either the water filter is not in correctly. The water line could be frozen in the door or in the cold water reservoir that is in the refrigerator section behind the bottom drawers. You can tell if it is frozen in the door if it is a SxS by unhooking the water line before it goes into the bottom of the freezer door. Just unhook it at the pressure fitting and then try to get water. If it is frozen in the door then water will come out of the unhooked line when you try to get water. Also could be a bad water valve.
Oct 19, 2014 | Whirlpool Refrigerators
Frozen winshield washer lines
Find a heated garage, you need to thaw out he lines, or use a hair dryer if you can follow the line path. When working, drain all the fluid by holding down the spray button on the car. Go and buy he heavy duty washer fluid with the lowest freezing point you can buy and refill your washer reservoir with it. Don't add any water Most likely you had water in the reservoir and it froze.
Jan 20, 2013 | 1998 Ford Taurus
Windscreen washer pump is frozen, cannot locate it to defrost, Also is there a winter setting on the engine?
If the washer reservoir is frozen, it must have been filled with plain water. It should be filled with washer fluid. Washer fluid contains alcohol to prevent freeze up. To locate the washer reservoir, look for the filler cap, it will say washer fluid on the cap.
Dec 22, 2010 | 1997 Toyota RAV4
On a GE side by side where is the water reservoir
I had the same problem. The line is frozen. GE will not admit there is a problem. I read a suggestion on line & followed up on it. I placed styro foam insulation on door inside the freezer compartment & no more frozen line & water flows freely.
Jul 14, 2010 | GE Profile PSW26P Stainless Steel Side by...
The water does not come out of the cool water dispenser and ice cubes come out when the water dispenser is pushed.
You may have an issue with the "electronic dispenser control board". Also, check your "water reservoir" located in the fresh food area (lower rear area) to ensure that the water is not frozen (if frozen, this will prevent water from dispensing at external dispenser).
Contact an appliance service company.
Feb 16, 2010 | KitchenAid Refrigerators
Water dispenser on refrigerator not working but ice maker is making ice
Most likely a frozen line... If you can hear a faint pump noise near filter when you try to dispense wate, that tells you the pump is woking. rIt could be a frozen reservoir(located on fridge side behind vegetable bins) or the line that runs thru freezer door to the dispenser. Use a hair dryer to thaw out reservoir or try to turn off the unit for a few hours. (That did it for me). If it's the line in freezer door, shut off unit, open freeezer door for a few hours and seal off freezer with a towel or cardboard to keep all frozen. If not this, may be a clogged water line from filter or a bad valve.
Dec 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i access my water reservoir on my ge side by side to see if it is frozen
The water reservoir is located in the fresh food compartment behind your crisper bins.
Dec 23, 2009 | Jenn-Air JCD2295HES Side by Side...
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Water filter is not dispensing water
Plugged filter maybe, or frozen reservoir behind the crisper. Or a bad water valve. If the frig was very cold recently check the reservoir first...
Eric
Oct 10, 2009 | Whirlpool Refrigerators
Water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Jun 17, 2009 | Refrigerators
Refrigerators Logo
357 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
