Question about Dell Inspiron E1505 Notebook
Dell laptop inspiron e1505 no boot green light comes on for about 5 seconds, plugged into a working monitor and still no screen, reset ram, and I dont hear any fans or hard drive running.
  • 244 Answers
Could be a case of overheating.
for starters clean the fans with a mild vaccum...
If this doesn't help, the laptop needs to be opened and cleaned up internally, also apply fresh heat release compund to the processor.
That will solve it.
Don't forget to rate this answer if it helps
Posted on Jul 21, 2009
I have a Dell Inspiron e1505 laptop that just won't come on.
hi, your laptop led`s are also there for diagnostic purposes, if the caps lock and scroll lock (the one on right of caps) are flashing before going off, it means your system is not detecting the RAM so either your ram has failed or the motherboard is faulty
Jan 14, 2010 | Dell Inspiron E1505 Notebook
Dell E1505 Intermittent display loss CPU: Intel core duo T5300 2.0ghz RAM: 2gig PC2-4200 ram (Hynix is the brand i think?) VID: ATI X1400 256mb HDD: 80gb 5400rpm hd OS: Windows Media Center w/ SP3 and...
You might be able to verify by taking a fairly bright flashlight and aiminig across your screen when it does shut off. If you can see the image, it's probably the inverter.
If you've tried an external monitor and it does the same thing, it's probably the video card (hopefully yours is the replaceable kind.)
Six screws on the bezel and carefully pop it off. The inverter is on the bottom of the screen. I just replaced a broken screen on that exact model.
Jan 08, 2010 | Dell Inspiron E1505 Notebook
Have an Dell inspiron e1405 laptop. Screen is not
Try new memory (RAM) or if the device has two memory module install turn the deviice off take one module out turn on
If it does not work then
Turn the device off take the second module out replace with the first module
Turn the device on
Jan 06, 2010 | Dell Inspiron E1405 Notebook
I have a dell e1505 laptop you turn it on it flickers to dell for about a 1/2 second then goes virtually black but if you look real close the screen is there.you can still hear it, i hook it to a exteral...
hi there !
-if you switch the computer on and it boots up and you hear the windows sound, this could be a possible video problem or motherboard problem
-run the diags on the LCD, while the computer is off, press and hold "D" then press power button at the same time, if you see the colors red blue green without any problems then it is a motherboard or video card problem
-another method to run the test is while the computer is off; preess and hold Fn then press power button, let the test run; when you see the question were colour bars displayed, press N, if you see the colors red blue and green without any problem then it is a motherboard problem or video card; otherwise it is an LCD problem
-to toggle display on the external monitor press Fn then F8
cheers !
Oct 20, 2009 | Dell Inspiron E1505 Notebook
Getting a white screen at start up on a Dell Inspiron E1505. If I let it sit it will flicker and come back on after about 15-30 min and will not return to white screen. Is it time to replace the lcd?
Try system recover.
if it happens the second you boot your computer, is the screen dark but the back light is just on, or is it that the screen is completely white?
Jun 22, 2009 | Dell Inspiron E1505 Notebook
Blank screen when powered on.
Do you have any CD’s that came with your laptop? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. To boot from that CD disk, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. You can also boot from the Windows reinstallation disk. If the computer boots from either CD, then your Operating System is corrupted and needs to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron E1505 Notebook
Dell inspiron b130 won't boot up.
Connect an external monitor to the laptop and see if you can see what is happening on that.
It is a possibility that your inverter is faulty and will need to be replaced. They will normally power on for a few seconds, then cut out.
Remember to set the laptop to use the external monitor with the function keys.
Apr 09, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron E1505 Notebook Logo
340 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
