Question about Fender Music
I bought a used black Fender Stratocaster about 20 years ago with the serial # H 035195 silkscreened on the headstock. At the base of the neck near the body, it has stamped " Made in USA".
The tuners look like Fender tuners but without the "F" on the back of them. I was told by the owner of the store that it was made here in the US designated for export. I am confused since the "H" designates it's made in Japan but the "Made in USA" which is clearly stamped at the base of the neck has me confused. Also the truss rod hole at the headstock is plugged. It has the dark wood but is solid instead of having a hole. Did I get taken or is this some oddball thing. Is it worth anything? Please help. Henry Ducassi Ft. Lauderdale, Fl.
    Top Expert:
  • Fender Master
  • 3,113 Answers
I suspect the H is really an N, which would place it.1990-91. As long as the adjustment screw for the truss rod is at the base of the neck. The plugged top end isn't a concern. Your best source of info is to contact Fender customer service directly. Here's the link-
Contact Fender Musical Instruments Corporation
Posted on Dec 20, 2016
Testimonial: "Thanks for your input. It is definitely an "H". I will contact Fender to see if they can shed some light. Thanks again, Henry"
V130147 fender Stratocaster reissue serial number .Im trying to find out what year it was made I think I purchased it in early 90s late 80s
That serial number could be for a guitar was made in Corona California, but it does not give the year, which should be visible on the neck of the guitar.
It could be for a guitar made in the Fuji-Gen Japan plant, in 1996-1997, in which case it should show a neck decal "Made in Japan".
Dec 05, 2016 | Fender Music
I have a Fender Stratocaster with the serial number 006022 printed at the top of the headstock. What year is it?
Those numbers don't correspond with normal Fender numbering schemes. Are there any letters preceding the numbers? Where was the instrument made?
Nov 19, 2016 | Fender Music
I have a Fender Squier Stratocaster Standard HSS. Serial number: ic071104059. i am trying to determine the year and specifications
It was made in 2007. If you call Fender directly they can sometimes id the exact model version from the serial number. The records they keep on Squier guitars is a bit sketchy, but sometimes they can help.
Oct 11, 2014 | Music
Woud you check fender serial number z6268670
Your guitar was made at the
Corona Plant (Fender), USA
in the Year(s): 2006 - 2007
Jul 26, 2014 | Fender American DLX Stratocaster V Neck...
I would like to know what year my fender stratocaster custom body guitar serial Number V033170 was Made and its aproximate value
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
The Year cannot be determined from serial number.
However, you can remove your neck and check the date there.
Worth: $800- $1000
Jul 24, 2014 | Fender Musical Instruments Corporation...
What year my fender stratocaster custom body guitar serial Number V033170 was Made and its aproximate value
I think it is a 2000 but take the neck off and look at the date for sure it is a U.S. vintage series guitar most likely a reissue of a earlier model
What year was a fender stratocaster serial number 33170 made?
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date (Note the earliest I'm seeing is mid 80s)
Serial number on a jazz bass ?
Check front of headstock, rear of headstock. Neckplate on the back of guitar. If not, remove neck and check the heel and neck "pocket."
May 12, 2014 | Fender Deluxe Active Jazz Bass Electric...
Fret buzz on new fender david gilmour Nos strat
fret buzz can usually be cured by adjusting the tension rod, unless the neck is permanently warped from excessive heat/humidity (from, say, being left in a car on a summer day).
hold the headstock up to your face, and look down the neck. you should see that the neck is uneven around the frets that buzz. if the neck appears straight when viewed from the headstock, down toward the body, then the strings are just too low, and the bridge should be raised. if you see unevenness in the neck, however, when viewed this way, you should attempt to use the tension rod to straighten the neck.
the tension rod can be adjusted with the hex bolt that pokes out at the base of the headstock, right from under the top of the fretboard. use an allen key to gently turn the tension rod either way until the neck begins to straighten out. if the tension rod cannot straighten the neck, then the neck is warped from heat/humidity.
Mar 09, 2011 | Fender David Gilmour NOS
Music Logo
21 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
