My duo therm furnace is blowing cold air and it is 9 degrees outside
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
  • 10 Answers
SOURCE: I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
Posted on May 31, 2009
  • 614 Answers
SOURCE: can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Posted on Jun 25, 2009
  • 20 Answers
SOURCE: Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Posted on Aug 22, 2009
  • 164 Answers
SOURCE: Air Conditioner stops blowing cold air when vehicle is not moving
plus one on the cooling fan problem. if it was low on charge then as you slow down, condensor temps and line prressures would raise therefore it would cool at low speed and and not when moving since the incoming air would drop system temp,reducing line pressure and then cusing compressor to cycle. the auxillary cooling fans must be on whenever a/c is on, if not, thats your problem. get this taken care of because if you get stuck in traffic, your engine will overheat also if fans are not running
Posted on Sep 02, 2009
It is 9 degrees outside and my duo therm furnace is blowing cold air
I hope you have fixed it by now. Probably was the limit switch? don-ohio
Dec 18, 2016 | Heating & Cooling
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Furnace refuses to cycle off even when room is 20 degrees warmer than setting
Do you know how to access your furnace wiring ? What make/model furnace?
Jan 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
It is getting cold can you tell me how do i work the furnace part of my duo therm dometic air system
I hope this doesn,t sound patronising but i have seen people turn the themostat down to make the furnace come on obviously the thermostat has to be turned up to set for a higher tempreture , after a small time delay, should then light up.
Oct 20, 2011 | Dometic Rooftop RV Air Conditioner
Air stop blowing cold but sill runs
What is the brand of rv ac you have?If you have a duo-therm I had the switch go out ..Not the one that says low-meduim-high but the one next to it that has various sub settings..
Jun 11, 2010 | Dometic Rooftop RV Air Conditioner
Duo therm AC/ furnace in Puma not kicking on
there is a "control unit" inside the bottom cover of the A/C on your cealing ... inside there is the control box that controls itself. Has a silver peice bout 2'' thick and the size of a quarter this is your freeze control, if your A/C gets TOO cold and might damage itself it kicks on and shuts down your unit(yes even your furnace) need to have a tech come out and fix/replace it, RV Tech, most A/C repair companies know NOTHING about RV's
Nov 17, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
