Contrast on flatscreen tv keeps going back to 100 even though i hit the enter butto
  • 28 Answers
SOURCE: contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Posted on Jun 10, 2009
Geekman
  • 32281 Answers
SOURCE: it looks very dark
The fault could be a faulty inverter board or a faulty CCFD lamp.
The inverter supplies high voltage to the CCFL lamp. The CCFL lamp is a mini fluro lamp and can dim with age.
Check LCD Parts for service, parts and DIY info - click on this link to their WEB site : -
www.lcdparts.net
Posted on Oct 06, 2009
Sarethan
  • 76 Answers
SOURCE: contrast 100 box
That would be the monitor and not the PC. try going to menu on the monitor and doing a factory reset.....if that doesn't work unplug for 3mins and try agin....if neither work then your monitor is faulty. Hope this works out for ya
Posted on Nov 02, 2009
SOURCE: my zoom level which I have always had fixed at 150
Hi ianni7,
Are you referring to the zoom level in Internet Explorer? Or the zoom level in Magnifier?
Posted on Nov 26, 2010
seeker5211
  • 1089 Answers
SOURCE: I have been having trouble
!st thing that I do with intermittent fax problems is to call the phone carrier.
Tell them that you are having fax problems. Ask them to test your line. You could have a bad cable or noisy line.
Posted on Jul 10, 2011
Battery won't fully charge.
Does the battery % stop at 85% or does it get to 100% and reduce to 85% when disconnected?
I've read several articles about battery charging and several have stated that when the phone hits 100% on the charger it will slowly decline even though it is left connected. Basically, it hits 100% and acts like it's disconnected (even though connected). When disconnected the battery percentage will drop. I'm not sure if this is what you are experiencing or if it's a problem with the device.
To start, I would suggest backing up all data on the phone and sync with Google. Perform a factory reset and log back into the device. This may solve the problem. If not, then I'd suggest going back to your service provider
Aug 27, 2013 | LG Motion 4G MetroPCS
Can not reset calculator. Keep getting + sign when press enter
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Feb 24, 2013 | Texas Instruments TI-84 Plus Calculator
Will not store settings unless kept in standby. Contrast/Brightness/Colour/Volume
1. The on/off switch is not easily accessible because the remote control is used to turn the TV on and off.
2. If the remote is used, the TV is always in standby mode
3. When the power is turned off and then back on those settings go back to their preset values or the last preset settings.
4, You should be able to enter the preset settings with the original remote control,
Sep 17, 2017 | Watches
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
What are the best settings so that i can get the best picture from samsung plasma tv model PS50A457P1D?
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Mar 09, 2012 | Samsung PS50A457 50 in. Plasma TV
I in mi aoc tv lcd l22w89 the option picture blocking, contrast and brightness to 100% and I can not change
In the menu system there is a reset (I believe it's all reset, or reset all...something like that) which should fix the issue.If not, leave the TV unplugged for 4 hours and plug it back in then turn it on.
Nov 26, 2011 | AOC L22W898 22 in. LCD TV
I keep getting a box on the screen to adjust brightness and contrast. How can I stop this happening
adjust them.....hit enter on remote....good success...Regards, medr's tv service
Oct 15, 2011 | Computers & Internet
I have been having trouble receiving faxes. It doesn't always happen, only occasionally. The printout says "no fax detected"; even though it has rung, it doesn't seem to connect....
Jun 27, 2011 | HP LaserJet 3050 All-In-One Printer
I have a 36inch panasonic tv thats not a flatscreen its bulky. after a few mins of watching tv or playing games the screen gets black cept for this horizontal line with the picture in there i gave it a...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )..............
May 12, 2011 | Panasonic CT-36D20 36" TV
JENSON vm9312 Video Bypass
check this out man, go to fm/am mode. with the remote hit the setup botton. then enter 543210 and be sure it beeps on every diget. then hit the hammer/screwdriver icon and turn the parking brake "on"
Oct 09, 2007 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
